My dvd/cd player will not play dvds comes up saying no disc but plays cds
    Scholar:
  • 102 Answers
There are two LEDs in a DVD player. One is the right "color" for CDs and the other is for DVDs. Clearly, one of these LEDs has burned out. This is one for factory repair, if under warranty, or may be reparable by a local repair service.
Posted on Oct 06, 2009
Led combi will not play dvds but will play cds
The DVD laser pickup is at the end of life, CD's work because runs at slower speed and does not require the higher precision, the whole assembly would need to be replaced, far cheaper to replace the player.
Jun 10, 2012 | Televison & Video
My dvd player will not play any dvds or cds... It says disc error
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | Audio Players & Recorders
My dvd player plays cds but wont play dvds says disc error or unknown disc
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
My dell dvd rom can't read some cds and dvds
you were saying some? and not all the cds and dvds? it may be that those other discs are unreadable anymore caused by scratches, marks, or the like. if other discs can be read then the player is all good. also check what file format you are trying to play. it may also be that the file format you are playing is not compatible with the program you are using to play it with like windows media player, media classic, etc.
Apr 03, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Loading Problem
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
May 25, 2009 | Philips LX3600D System
Won't play DVD's but will play CDs
I suggests to try another dvd dics maybe it is not compatible to your player. try universal dvd dics...
Apr 16, 2009 | Televison & Video
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Lg da3520 home cinema system refuses to play DVD discs. It has no problem playing CDs but DVDs it either says "Check Disc" or "Disc Error" or continues to attempt to load the disc but...
you have probably to clean up your dvd player with a clean up CD. After that if your dvd player doesn't want to read a dvd but play a cd, your laser output must be to fix. you'll have to go to a specialist.
Apr 23, 2008 | Televison & Video
Will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
