Can not tune the tv
When in the menu screen i press auto tune the tv, it goes through the whole search file to finish on a blue screen and no channels saved
    Novelist:
  • 176 Answers
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Posted on Oct 06, 2009
How do you auto tune the Radio channels in or even do a search for different channels?
get the on screen menu up ( press menu on the remote) move around until you find auto tune , move sideways and it starts auto tuning
ti finds all radio and tv stations for you
when finished it may auto save or you will be required to press the ok button then exit
Mar 15, 2016 | Televison & Video
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My freeview needs retuned
If it is built in. Do the following.
Press the button on your tv remote that says TV/DTV.
Make sure it says DTV on the screen normally at the top corner of the screen.
Now with the Tv remote press the menu button. you should now see a menu appear go down to Auto Tune / Auto Store and press select or enter. T
his should now start searching through for you Freeview Channels. Dont be alarmed if you dont see many channel appear at the beginning of the scan as it normally goes past 75 % before they start filtering through.
If your box is a standalone then Just use the Freeview box remote and then press the menu button. go down to Install. this would then prompt if you would like to do a full search or add channels. I would do full search this will Delete all the channels previously installed and search from scratch.
I hope this sort out your Freeview
Little Dish Fitter
Sep 22, 2009 | Samsung Televison & Video
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Televison & Video Logo
342 people viewed this question
Top Televison & Video Experts
