Question about Maytag Kitchen Ranges
The oven won't heat above 300 degrees and the oven burner won't light all the way around until you blow on it.
5 Suggested Answers
  • 105 Answers
SOURCE: OVEN UNABLE TO HEAT ABOVE 350 DEGREES
If it was an electric oven, it would likely be the heating element itself. But since it is gas, we have to look elsewhere.
The most likely culprit would be the temperature sensor inside the oven, & that is not registering the temperature correctly. It is saying that it is a different temperature than the oven really is, so that you cannot get it to go higher. Typically this would not be a user replacable part. If you can find your manual for the range, you would be able to tell for sure if it is user replaceable or not. If you need to call for service, GE has a reasonable price for their service calls - and they can also check the range and oven nozzles etc to make sure they are functioning correctly. Or put another way, you can have them do a preventative maintenance check on the whole thing while they are there. Be sure to tell them what you know it is doing ahead of time as well as the model and serial numbers, so they can have at least some of the parts with them.
Good luck.
Posted on Jul 25, 2008
  • 30 Answers
SOURCE: f3 fault code when trying to heat oven above 300 degrees.
I believe that is a short in a sensor. Does it heat to the proper temperature?
Posted on Apr 25, 2009
fixyourboard
  • 310 Answers
SOURCE: My oven will not heat above 190 degrees. It just
Sound like the bake element has gone bad.
Posted on Oct 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: my gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Posted on Dec 26, 2009
Heater will not activate until outside temp. is above 40 degrees
If you have a heat pump the compressor is locked out below that temp. If you have a dual fuel - hp/gas, the gas burners should come on as would the electric heaters if you have electric heat as backup.
Jan 19, 2016 | Heating & Cooling
Why won't the fan switch of after the oven is switch off
Not sure what fan your question refers to, but the fan that removes the heat from above the oven is controlled by a thermostat. It normally does not come on until the air temperature above the oven space is about 300 degrees and does not turn off until it is below 300 degrees.
Feb 25, 2015 | Ovens
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
Hardwick oven
replace the sensor in the oven as it tells the E R C ( clock) what the tempt is and the clock turns of the power . if this does not correct then replac the colck ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
My gas oven will not heat up above 300 degrees and
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Grill not getting hot, fire not around burners, knobs are so hot you can't touch them. not getting over 300 degrees, fire seems to be behind knobs
We assembled our new Genesis E-310 yesterday. Went together nicely, but won't heat above 350 or so. It should get to 500-550 degrees withing 10-15 mins. Any ideas of what could be wrong?
May 11, 2009 | Grilling
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Kitchen Ranges Logo
29 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
