Question about Durabrand CD-895 Personal CD Player
What does the U shaped image mean on the display screen when I insert a CD? I've lost my operating instructions
I've lost the cd that came with my s405 printer
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 24, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How do I upgrade my windows 7 to XP or atleast 2000? Pls help
you mean how do you downgrade your windows 7 to xp, you will need a copy of xp and boot from the cd and follow the instructions to install XP
Mar 28, 2011 | Microsoft Computers & Internet
I lost my driver cd for my lexmark z611 printerr
The Lexmark Z611 printer drivers for Windows operating system can be downloaded from the Lexmark website at http://bit.ly/aw8C7C. You can select your operating system by clicking on "change OS" .(see sample image below)
Then click on "FILTER". (see sample image below)
NOTE: FOR LEXMARK Z611, USE VISTA DRIVER IN WINDOWS 7. Then click on the driver under "Recommended Downloads". Download the file and follow the instructions on your computer screen. Hope this helps. Thanks.
Nov 10, 2010 | Lexmark Z611 InkJet Photo Printer
The windows connot open cause the account and password i lost
http://download.imgburn.com/SetupImgBurn_2.5.2.0.e
xe
http://trinityhome.org/Home/index.php?
wpid=1&front_id=12
ON ANOTHER PC...
DOWNLOAD IMAGEBURN, THEN DOWNLOAD AND SAVE TRINITY
RESCUE CD ISO TO DESKTOP. BURN ISO IMAGE TO
CD/DVD. ENTER SETUP, CHANGE CD/DVD TO FIRST BOOT
DEVICE. PUT CD IN DRIVE SHUTDOWN REBOOT AND FOLLOW
INSTRUCTIONS TO RESET PASSWORD. BOTH SITES HAVE
EXCELLENT INSTRUCTIONS. ALL FREE
Hope this helps
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
Unable to install XP in CQ60-104tu compaq Presario
You may find that if you insert a blank CD instead of DVD you have more luck (the image you have created is a CD image not a DVD image). Another tip is that you should not copy the ISO image to CD but using Nero burn image to disk. Let me know if you need more help.
Jun 09, 2009 | Computers & Internet
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
How I can instaled a hp deskjet F340
To download the software, do the following:
  1. Go to the Drivers page for your product. (see #2)
  2. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1128309&
  3. Click your operating system.
  4. Follow the instructions on the page that appears to download and install the software.
You can also use the CD that comes with the product although the downloaded drivers are usually newer and more reliable. I would recommend using those if possible
If you choose the installation with the CD.. here are the instructions for that
  1. Insert the product CD into the CD-ROM drive on the computer. The startup screen displays automatically. If the startup screen does not display automatically, use the following steps to start the installation manually:
    1. Click Start .
    2. Click Run . The Run dialog box displays.
    3. In the Open: text box, type D:\setup.exe , where D is the letter of the CD-ROM drive, and then click OK .
  2. Follow the instructions that display on the screen
Hope that helps,
Take care,
Michael
Nov 18, 2008 | HP Office Equipment & Supplies
Alpine CDE-9841
Have one solution which might work.
Remove head display unit and press reset dutton usins a pin.
now connect head display unit. now insert CD. make sure the CD is in good shape.
Cheers
Alex Victor
Jul 26, 2008 | Alpine CDE-9841 CD Player
Cant open mp3 files
Hi, When folder icon displayed on the screen it means it has subfolders,press enter and you can go in to the sub folder please see the attached image all the best sreejith
Jul 16, 2007 | Legacy LDTSN7 Car Video Player
Durabrand CD-895 Personal CD Player Logo
21 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Jonathon summesfield
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
