Question about GPX MW-3847 MP3 Player
Can I only charge battery with computer? will cellphone charger with usb connection work?
    Problem Solver:
  • 11 Answers
You might be able to or you can also buy the right charger for it.
Posted on Nov 11, 2009
Charging hiting
what model of cellphone you have... and what heated up is it the charger or the cellphone.. we have two problem either the cellphone or the charger.. but i will tell you to look for another charger where we can check your cellphone. A charger must stop charging when the battery reaches its peak of charge... if the charger doesn't stop charging even the battery is charged then it will cause over heating to the charger or to the cellphone...
Sep 22, 2013 | Cell Phones
Galaxy Problems
Sport mate, but it appears your device is communicating with you but you aren't decoding. *smiles*
First, you've got several problemchallenges all present in your device/tech gadget.
MTP- media transfer protocol...connected
USB connected.
To resolve, navigate your way to Settings/ developer options/USB debugging
Click on this and get the ? off, first.
Click again and get the ? back on.
Next, select from the displayed menu the option for USB charge only. EXIT.
Problem 1 solved.
Battery with red X marking on it while on display.
Battery is no longer considered GOOD? by your phone/tab.
Needs to be replaced.
Problem 2 solved.
Why Cellphone/tab not charging?
Check the recommended AC charger rating for your device/gadget, first.
Check the charger rating you've been using to see whether these values match.
Output DC=????
mAmps=????
Lastly, issue with Indpsert SIM card.
You need to confirm whether your cellphone/tab is locked to a particular Network carrier company or not.
If locked, you need to jailbreiak/unlock it.
Otherwise, a technician may have to check the SIM card terminals for you.
Hope these tips help. Feedback please. All the best.
Feb 05, 2018 | Samsung Galaxy Tab 8.9 3G P7300 16GB...
How can i charge rechargable batteries without usb cable for GE c1433 digital camera
The C1433 is a camera, not a battery charger. It uses standard AA batteries, either disposables or rechargeables. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Feb 11, 2013 | Cameras
When i started using usb cable wire to charge my phone it started not to work on the charger..
try the charger pin the usb port is not able to charge the cellphone it uses to connect the device to computer
Feb 05, 2013 | Samsung Corby 2 GT S3850
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
Dec 13, 2012 | Vivitar ViviCam 8025 Digital Camera
Can you charge camera from USB?
You don't say what make or model the camera is, so I can only answer generally. Most cameras, as opposed to most cellphones, do not charge the battery in the camera at all. They are supplied with a separate mains charger- you take the battery out of the camera and put it in the charger. I have a number of cameras with USB connectors, and none of them charge while connected to the computer.
If you bought the camera new, and it came with a charger, then the camera almost certainly needs the charger to charge the battery. If you purchased it used or it was a hand-me-down, and you didn't get a charger, then the seller or giver has probably been remiss. It won't hurt to leave the camera connected to the computer's USB port to see if it will charge, but when that doesn't work, you can find a replacement charger for your camera by searching Amazon with the camera model number and the word "charger". Better, you can get a "universal" charger on Amazon for as little as $4 that will charge any of the small lithium batteries used in cameras and phones (assuming this isn't a huge battery of the kind fitted to older video cameras). I have a universal charger and it is easy to use and has saved me a lot of money as I no longer need to buy a replacement for every type of battery I come across.
Jan 02, 2011 | Vivitar Cameras
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
Have a motorola v3X Suddenly not charging
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Jan 14, 2009 | Nokia 3650
IT KEEPS TURNING OFF WHEN I PLUF THE USB IN THE COMPUTER AND WHEN IT CHARGERS,FULL BATTERY,IT DIES OUT QUIKC
i guess theres a problem with the board of your cellphone,there might be some components that has been shorted out and thats the reason why it drains battery so fast and it shutsdown upon connecting to the usb
Jul 17, 2008 | Samsung Cell Phones
GPX MW-3847 MP3 Player Logo
75 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
