Question about Car Audio & Video
The battery drained in our car when we went to jump it the cable were put on the wrong sides the car radio stopped playing music and the navagaition system dose not work the radio also has plays sirius music but it has some electric functions still the screen says Check Map disc It also has 2 small boxes that say (Display open/close)the other box says (Disc eject) this is one the screen it also opens and close when that box is pushed and a CD OR DVD can be put in but does not play and then ejected out the open button also works to close the screen the name of the unit radio is eclipse it is a AVN5435 its an aftermarket radio I think and the car is a used 2005 Seana Toyota PLEASE HELP ME find a disc and that its affordable
  • 4 more comments
  • m_amara Oct 06, 2009
    I have looked in manual I have the installition guide and I need the map disc to reboot the system and get the code
    what do you think
  • m_amara Oct 08, 2009
    The radio dose have power the screen opens and close but no sound I have had it looked at the fuses are fine we burned out our ABS brake we had the electric system checked its OK please find me a disc that I can afford to buy or download
    I have I am waiting for help
    I can't tell you anymore the problem is that
    I thank you for being such a help I guess that's the only way to go . If any of your readers now what I need please contact me on you sight and send me an e-mail THank you again I have never used the internet like this. You saved me alot of time. good job
    President:
  • 1,653 Answers
I would say that your best option would be to trawl eBay for some bargain alternatives and most of what is available will fit the Toyota anyway. Its really all a wuestion of what features and power you want and how much you are prepared to pay.
Posted on Oct 08, 2009
    President:
  • 2,600 Answers
I think you going to have bigger problems than the radio and nav system not working. You reversed the polarity on your electrical system during te battery jump. That has most likely caused electrical damage you may not be aware of. Your electrical system most likely needs to be checked, especially the alternator. Find a good mechanic and explain exactly what happened so he knows what systems to check.
Posted on Oct 06, 2009
    President:
  • 1,734 Answers
Check the troubleshooting section in your manual.
If you don´t have one, check here
I searched this for you. Pls leave a good rating.
My battery is not being charged on my 2003 Mercury Mountaineer 6 cyl engine.
alternator !
it must generate 13.4 volts to charge the car battery . I am betting it is the alternator .
$400 AUD to replace happened on my car left me stranded 130 km from home !
car lights went dim , car radio cut out, car stopped and would not start . Stuck in traffic ! . Road side assistance had a jumper battery car started , moved car out of traffic . remove jump battery car stops !
had to wait 12 hours for a replacement alternator from road side service to be installed.
Dec 05, 2017 | Mercury Cars & Trucks
Music and radio
Start by replacing the 15A radio fuse. That should solve the problem.
Apr 10, 2014 | 1995 Lincoln Continental
Parasitic drain in my truck
either remove the battery terminals each stopping point
until you check starter and ignition and alternator
if the parasitic drain started straight after the radio install
return to that after market installer
and get them to explain why
Mar 07, 2017 | 2002 Chevrolet Avalanche
No power no lights 1995 nissan quest
Clean the battery cables, you must have a bad connection, use baking soda in a hot water solution and soak the cable ends and then wire brush and clean the opening with a battery cable cleaning tool available from any parts store for about $2.00
Oct 25, 2012 | Nissan Quest Cars & Trucks
Killed then we jumped started it it went about 2 miles and killed again. we jump started it again,got it running as soon as we took the jumper cables off the running car it killed
if you have a bad altinator it will drain your battery causing the enguine to stop running. and if you killed the car that was jumping it then i def would get the altinator tested on both cars as jumping a car with a bad altinator can cause charging issues on the car doing the jumping.
Jan 29, 2011 | 1997 Pontiac Sunfire
My clock and radio are suddenly not working in my 2003 grand am
Your Vehicle has two fuse boxes one fuse box under the hood and one inside the vehicle. Check your owner’s manual and you should find the fuse panel at the side of driver’s dash console. Look at the fuse schematics for the fuse description radio then remove that fuse for a visual inspection. If it is good it could be an internal radio problem. However, If the battery jumper cables were hooked up incorrectly it may have damaged a battery cell or the regulator of the alternator and I would have her take it to NAPA, O’Reilly, or Auto Zone to have a free battery and charging system test.
Apr 02, 2010 | 2003 Pontiac Grand Prix
I had to jump start my 82 ford econoline. does this blow most of the fuses in the fuse box. my after market radia has stopped working
No not usually. It's high current flow that blows fuses and unless you put more than 12-14 volts onto the battery no harm could be done. However if you accidently reversed the polarity (put the cables on back to front) then you would cause damage to the alternator diodes and the battery would drain back though them. If the radio was switched on at time of jumping, it would be damaged.
Mar 20, 2010 | 1983 Ford Econoline
Cars lights go dim or won't work,radio stops working, air stops w
Have the charging system rechecked. It sound an AWFUL lot like an alternator not charging the battery to me.
Feb 17, 2009 | 2002 Kia Rio
Own a 2005 ford 500. recently had front and rear pads replaced at 93k miles. Several days later warning lights started on startup ABS etc. Several days later unable to start car, battery drained. Jumped...
Firstand foremost,this snota problem for a echanic tooodagnose. Ifurbatery isdrainng, u shouldcek to cifur charging system is functioningproperly. Ifur ABS lite iscoming on, probaly during dis-assemby, something went wrong witur sesors. check it out with someone knowledgeable and experienced
Jan 25, 2009 | Ford Five Hundred Cars & Trucks
2002 diville radio wont stay on for more than 5 sec
hi i have a 2002 dts and had the same problem. i recently had work done to my car and suddently my radio stop playing. well recently my battery went dead and i got a jump start and that fixed the problem. maybe if you disconnect your battery and re-connect that might reset the system. i found out the hard way, but since i jumped my car the radio has been fine.
Jan 02, 2009 | 2002 Cadillac Deville
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
