Question about Tappan TGF320 Gas Kitchen Range
Igniter keeps clicking ...gas all burners light, but clicking continues
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
The ignition on the gas top continues to click after being turned off
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 08, 2011 | Jenn-Air JJW8530C Expressions Collection...
Oven ignites but the ignition continues to click
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 08, 2010 | Rangemaster 110 (Gas) Kitchen Range
Igniter continue to click when off
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jul 30, 2010 | GE Profile JGP636 Gas Cooktop
Igniter misfire
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
The spark won't stop on a burner; it turns on just fine, but when off, it continues to click. That is, it is the spark that causes the gas to ignite. But the "sparker" keeps on sparking, over and over and...
Most of these have a switch behind each knob that triggers the spark.
OFTEN during cleaning, mositure gets into the switch causing the problem.
If you suspect this, try using a hair drier to dry out behind the knob if you can;t remove and investigate if this could be the cause.
Sep 15, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
913 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
