Question about Car Audio & Video
I have a pioneer 3000watt spl 4ohms sub.. hw do i wire it to run at 2 ohms please???
  • 84 Answers
i have a pioneer 3000watt spl 4ohms sub.. hw do i - 1_4ohm_dvc_2ohm.gif i hope that helps.if u need more help bertman285@hotmail.com
Posted on Oct 06, 2009
  • 70 Answers
You need another 4 ohm speaker or a power resistor and connect them in parallel to get to a 2 ohm load.
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Bridging amp/sub
wire speakers in series google it to find diagrams
Jun 30, 2009 | Car Audio & Video
Spl 620 wn put out loud enough does have sound did i wire it wrong?
Hello ace_sterling,
Not knowing what you have the SPL-620 driving or knowing how you have it wired, it's rather difficult to determine if it's wired "wrong".
I show the SPL DK2-620 as being a 2-channel amp with 150 watts output at 4 ohms, or 180 watts at 2 ohms. Even if the power is somewhat overrated, it should provide more than enough power for a set of standard 2-way or 3-way speakers, or component speakers with a separate crossover.
Powering one or more subs is another thing. You would get sound, but the subs would not be very loud. In bridged mode, the amp is only stable to 4 ohms. So if you are trying to power 2 4-ohm subs, the best connection would be 1 sub connected to each channel. If you are powering only 1 sub, then the bridged connection would be best.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | SPL Audio Car Audio & Video
Need help
Hello bully_bread,
Your amp will be powering the sub at 4 ohms.
The impedance or "load" that the amp sees is determined by the number of voice coil(s), the number of sub(s), and how they are connected. Whatever that final load, it is the impedance or "ohms" that the amp is supplying power at.
A single 4 ohm sub with a single voice coil cannot present a 2 ohm load. However, a sub with dual 4 ohm voice coils wired in parallel will present a 2 ohm load.
Here's a link to Rockford_Fosgate's "wiring wizard" where you will find all combinations of subwoofer wiring and the resulting loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Hope this helps.
Apr 13, 2009 | SPL Audio Phantom DK2-1000 Car Amp
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
