Question about Car Audio & Video
Light goes on indicating check air bag how do I do this?
  • 566 Answers
Hi from uk may i suggest you check under front seats and make sure the seatbelt pre tensioners wires are ok ie make a check on the plug connections try unplug and re connect ? as these are linked to airbag/s system also these wire can become loose with seat movement and also inadvertantly caught when vacuuming car under seats?
Posted on Oct 06, 2009
2006 lincoln town car air bag light is on 5 beeps 5 times
The five beeps - five times would indicate a code 55 , but factory service info only goes to code 53 .
  • Audible tone - DTCs retrieved
  • Air bag SRS system fault
  • REFER to DTC Priority Table.
Did your air bag light flash at all ? Apparently this will do flash the air bag light codes as well .
Symptom Chart Condition Possible Sources Action
  • Air bag warning indicator is illuminated continuously
  • Fuse
  • Damaged wiring, terminals or connectors
  • A faulty diagnostic connector
  • A faulted RCM
  • A faulty instrument cluster
  • Go To Pinpoint Test A .
  • Air bag indicator flashing
  • Air bag/pretensioner supplemental restraint system (SRS) fault
  • No communication with the restraints control module (RCM)
  • Fuse
  • Diagnostic tool
  • Data link connector (DLC)
  • A faulted RCM
  • Circuitry
  • Go To Pinpoint Test V .
LFC - light flash codes .
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Table
DTC a LFC b Description Action To Take - Continuous The Air Bag Indicator is Illuminated Continuously, RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of Signal Ground Go To Pinpoint Test A . B1231 13 Crash Data Memory Full Install a new RCM and impact sensors. REFER to Inspection and Repair After a Supplemental Restraint System (SRS) Deployment . B1317 Continuous Battery Voltage High CHECK battery voltage; to be below 16 volts. REFER to Section 414-01 . B1318 Continuous Battery Voltage Low CHECK battery voltage; to be above 9.0 volts. REFER to Section 414-01 . B1342 12 RCM Is Faulted Install a new RCM. B1869 NONE
Continuous lamp
Secondary air bag warning sounds if another fault is present Lamp Air Bag Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test B . B1870 NONE
Secondary air bag warning sounds if another fault is present Air Bag Warning Indicator Circuit Short to Battery Go To Pinpoint Test C . B1891 53 Air Bag Tone Warning Indicator Circuit Short to Battery Go To Pinpoint Test D . B1892 53 Air Bag Tone Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test E . B1921 14 Air Bag Diagnostic Monitor Ground Circuit Open Go To Pinpoint Test F . B2292 33 Restraint System - Safety Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test G . B2292 34 Restraint System - Safety Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test G . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2294 24 Restraint System - Curtain Fault (Driver Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2294 25 Restraint System - Curtain Fault (Passenger Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2295 22 Restraint System - Side Air Bag Fault (Driver Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2295 23 Restraint System - Side Air Bag Fault (Passenger Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault (Front Impact Severity Sensor Circuit Fault) Go To Pinpoint Test K . B2296 43 Restraint System - Impact Sensor Fault (Driver Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 45 Restraint System - Impact Sensor Fault (Driver Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 44 Restraint System - Impact Sensor Fault (Passenger Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 46 Restraint System - Impact Sensor Fault (Passenger Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2434 51 Driver Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test L . B2435 51 Driver Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test M . B2438 52 Passenger Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test N . B2439 52 Passenger Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test O . B2477 Continuous Module Configuration Error INSTALL a new RCM. B2691 51 Driver Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test P . B2692 52 Passenger Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test Q . C1414 15 Incorrect Module Design Level Go To Pinpoint Test R . C1947 49 Driver Seat Track Position Sensor Circuit Short to Ground Go To Pinpoint Test S . C1948 49 Driver Seat Track Position Sensor Circuit Resistance Out Of Range Go To Pinpoint Test T . C1981 49 Driver Seat Track Position Sensor Circuit Fault Go To Pinpoint Test U . - - No Communication with the Restraints Control Module Go To Pinpoint Test V . Your best bet have codes checked with a scan tool .
Jan 23, 2017 | Lincoln Cars & Trucks
Reset airbag light
Hey Earl, what's going on ? The air bag module is usually under the passenger seat or the center console ! The only way to turn off the light is with a up grade scan tool , not code reader. An the light is on for a reason , problem with the system ! If you don't know about this don't mess with it , you could deploy an air bag !
The AIR BAG indicator, located on the instrument panel cluster (IPC) is used to notify the driver of SIR system malfunctions and to verify that the SDM is communicating with the IPC. When the ignition is turned ON, the SDM is supplied with ignition 1 voltage and requests the IPC to flash the AIR BAG indicator 7 times. While flashing the indicator, the SDM conducts test on all SIR system components and circuits. If no malfunctions are detected the SDM will communicate with the IPC through the class 2 serial data circuit and request the IPC to turn the AIR BAG indicator OFF. The SDM provides continuous monitoring of the air bag circuits by conducting a sequence of checks. If a malfunction is detected the SDM will store a diagnostic trouble code (DTC) and request the IPC to turn the AIR BAG indicator ON. The presence of a SIR system malfunction could result in non-deployment of the air bags. The AIR BAG indicator will remain ON until the malfunction has been repaired.
Feb 06, 2015 | 2005 Chevrolet Tahoe
2006 chev aveo red air bag light is on and when some one sits in the passenger seat the passenger air bag light goes off. I looked at all the fuses and checked all the wiring. The light cand on when the...
The light indicates the Airbag control module has sensed a malfunction. It then sets and stores a trouble code and disables the system.
You will need a professional grade scan tool to access the Airbag module.
Sep 10, 2013 | Chevrolet Aveo Cars & Trucks
Abs light is stays on. The air bag light stays on as well. I have a 2004 Ford exploer sport trac 4x4
Get the fault code.
DTCa LFCb LFC Priority Description B1318 - - Ignition Voltage Below 9 Volts - - 1 RCM Disconnected, Inoperative, or Lost/Low Ignition Feed B1342 24 2 RCM is Faulted B1231 19 3 RCM Crash Data Memory Full B1921 21 4 RCM Bracket Ground Resistance High C1414 29 5 Incorrect Vehicle Identification Code B1887 15 6 Driver Air Bag Circuit Shorted to Ground B1916 15 7 Driver Air Bag Circuit Shorted to Battery or Ignition B1888 16 8 Passenger Air Bag Circuit Shorted to Ground B1925 16 9 Passenger Air Bag Circuit Shorted to Battery or Ignition B1932 32 10 Driver Air Bag Circuit Resistance High B1933 33 11 Passenger Air Bag Circuit Resistance High B1934 34 12 Driver Air Bag Circuit Resistance Low B1935 35 13 Passenger Air Bag Circuit Resistance Low B1901 14 14 Front External Crash Sensor Shorted to Ground B1941 41 15 Front External Crash Sensor Open Circuit or Short to Battery B2444 48 16 Driver Side Crash Sensor Internal Fault B2445 49 17 Passenger Side Crash Sensor Internal Fault B2441 42 18 Driver Side Crash Sensor Mounting Fault B2440 43 19 Passenger Side Crash Sensor Mounting Fault U2017 44 20 Driver Side Crash Sensor Communication Fault U2018 45 21 Passenger Side Crash Sensor Communication Fault B1993 36 22 Driver Side Air Bag Circuit Shorted to Ground B1992 36 24 Driver Side Air Bag Circuit Shorted to Battery or Ignition B1994 36 26 Driver Side Air Bag Circuit Resistance High B1995 36 28 Driver Side Air Bag Circuit Resistance Low B1997 37 23 Passenger Side Air Bag Circuit Shorted to Ground B1996 37 25 Passenger Side Air Bag Circuit Shorted to Battery or Ignition B1998 37 27 Passenger Side Air Bag Circuit Resistance High B1999 37 29 Passenger Side Air Bag Circuit Resistance Low B1892 - 30 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open B1891 - 31 Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition B1869 Tonec 32 Air Bag Indicator Inoperative B1870 Tonec 33 Air Bag Indicator Shorted to Battery - - - No Communication With the Restraints Control Module (RCM)
a DTC: Diagnostic trouble code
b LFC: Lamp fault code, flashed on air bag indicator.
Apr 21, 2011 | 2004 Ford Explorer
Service air bag indicator light on dash stays on
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to disarm the airbag system can result in an unexpected Airbag deployment and possible serious personnel injury disconnect the battery 30 minutes prior to start of work.
Sep 22, 2010 | 2005 GMC Sierra 2500HD 4WD
Air bag fault
In my opinion there might be a problem of wiring after changing the indicator console as there is connection problem of air bag in steering wheel. If there is a loose connection for any air bag the light goes on. You have to recheck the wiring and any loose connection for your air bag of steering wheel. But be sure to disconnect the battery terminals before you try to find out any fault in this area.
Jan 18, 2010 | Peugeot 405 Cars & Trucks
5 series' of 5 beeps in a row on start up
Check the Air Bag Indicator Light. When you turn the car on it should stay on for 6 seconds and then turn itself off. If a fault is detected in the system operation check, the indicator light will either fail to light, stay on continuously or flash. The flashing may not start until up to 30 seconds after the initial systems check.
If there is a fault in the system AND the air bag indicator light fails to light then an audible tone will alert you- it will be a set of 5 chimes (bells/beeps) five times in a row.
Have the Air Bag serviced and the indicator light bulb changed. Since the dash will be off in order to change the bulb, I would have all of the other dash lights changed at the same time. If one goes out, others will surely follow.
Corri R. / Service Writer
Jan 26, 2009 | 2002 Mazda Tribute
1999 f150 airbag light stays on after blinking upon start up!
Passenger Air Bag Deactivation (PAD) Switch
The passenger air bag deactivation (PAD) switch:
  • is located on the instrument panel to the right of the climate controls.
  • contains a light emitting diode (LED) that indicates when the PAD switch is activated (passenger air bag disabled).
  • allows the passenger air bag deployment circuit to be disabled using the ignition key.
  • should be used whenever a child safety seat is being used in the front passenger seating position.
Prove Out the System
Prove out the system means to turn the ignition switch from the OFF to the RUN position and visually monitor the air bag indicator with the air bag modules installed. The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag supplemental restraint system (SRS) fault is present, the air bag indicator will either:
  • fail to light.
  • remain lit continuously.
  • flash.
The flashing might not occur until approximately 30 seconds after the ignition switch has been turned from the OFF to the RUN position. This is the time required for the restraints control module (RCM) to complete the testing of the SRS. If the air bag indicator is inoperative and an SRS fault exists, a chime will sound in a pattern of five sets of five tone bursts. If this occurs, the air bag indicator will need to be repaired before diagnosis can continue.
Active Commands
This command allows the technician to verify operation of the air bag indicator, passenger air bag deactivation (PAD) lamp and chime. When the air bag output command is executed, the indicator, the PAD lamp, chime and the chime are activated simultaneously for approximately four seconds. All devices are deactivated automatically.
Jan 15, 2009 | 1999 Ford F150 Regular Cab
"Check" indicator light
The Check light is on because one of the sensors in the system is not being read properly by the vehicle ECU. You need to take it to someone & have a scan tool hooked up to it to extract the
DTC(s) that may be stored. Please be advised that a loose Fuel Cap will set the Check light for sure.
The Air Bag light does a self-test, and, if no one is in the passenger seat, it turns to the "Off" setting. There is a sensor under the passenger seat that tells the Air Bag ECM this. The light is there to let you know that the pass air bag will not go off, in the event of a collision, and no one is in the pass seat. Saves the inmsurance company money, probably.
Sep 07, 2008 | 2005 Toyota Corolla
Performance indicator light
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
