Question about GE DBXR463EBWW Electric Dryer
GE Dryer Model # DBXR463EBOWW
Does anyone know the age of this model dryer?
  • 1122 Answers
SOURCE: HELP!!! Dryer will not work!!! MODEL#DBXR463EBOWW
check the door switch and the heater box main fuse,let me know-mike
Posted on Oct 26, 2008
TheMobilian
  • 8220 Answers
SOURCE: How do you crack open the GE Dryer
Check out my handy GUIDE
Posted on Jun 14, 2009
  • 25 Answers
SOURCE: Kenmore washer dryer age?
Next to the serial number there should be a manufacter date. that is when it was made. I am guessing 2 years old.
But check on the back, it is peobaly printed on a small metal tag.
Most electronics have a manufacter date posted on them for warrenty sake. yours may still have a warrenty. you can also go to Kenmore website and in the search area type in the serial number and it can tell lots of info including if it is still under warrenty. wouldn't that be a nice surprise!
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: MOTOR
Here's the part numbers for the motor and the substitution version, as the older one might not be available any longer. You can order this from the searspartsdirect.com website for $169.31 and it's in stock. Please verify this is the correct part for your dryer before ordering. Hope that helps! Number: WE17X0032 Substitution: WE17X10010
Motor asm Number: WE17X0032 Substitution: WE17X10010 $169.31 In stock Quantity Add To Cart Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032. Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032.
Posted on Jul 28, 2009
hektor1961
  • 70 Answers
SOURCE: How do you change belt on GE dryer model
You have to open the door right where the door closes if you look up you'll see two screws take those out and the top just comes off by lifting it up and then on the inside if your in the front of the dryer the screws are pointing to you so once you got the top look at the front panel but from the inside and at the top you'll see two screws one on left one on right take them out and grab the front panel and just lift it it sits on two little hooks or screws on the bottom i usually lift right and than left or left then right.
You will now have access to slide the new belt around the drum and ready to mount on the motor pulley and idler.
Pull your dryer from the wall and remove the back panel by the vent outlet.
You will see a diagram of how belt mounts over both pulleys, follow instructions and reinstall everything the way it was.
GOOD LUCK!
Posted on Aug 30, 2009
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
Does a ge gas dryer with the model number DBSR453GBOWW have a pilot light?
Your GE dryer does not have a pilot light, a common issue on gas dryers is the ignitor. More info needed (what does the dryer do or not do when you push the start button?) to give a better answer.
Feb 12, 2015 | GE Dryers
Dryer does not heat
My GE (model #:DCL333EAOWW) Dryer does not heat up and the timer on the dryer does not work. Does anyone know what I would look for to fix this problem on my own?
Jan 16, 2011 | Dryers
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
I need to know how old this dryer is Model 66814690 serial MG 1316480
The date of manufacture (month and year) are calculated by the first two letters of the serial number. The first letter being the month and the second letter is the year. The year letter code rolls over each 12 years so you have to know the age within 12 years. The link below will give you the guide to calculate.
Date Codes
Sep 23, 2009 | GE DWSR405EBWW Electric Dryer
How do you change belt on GE dryer model DBXR463EBOWW?
GOOD LUCK!
Aug 30, 2009 | Dryers
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
Mar 22, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
737 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
