Question about Sony DSR-1500 Mini DV VCR
DSR-1500 firewire port doesn't work. Any
DSR-1500 firewire port doesn't work. Is there a list of common failures published somewhere? It is plugged into a DVP-25a board.
  • 4 Answers
It may be that the firewire cable has been inserted the wrong way round. Unfortunately this is a common problem as it is quite easy to do this especially when fumbling around with limited access behind the deck. Worst case scenario is that the Firewire circuit board has been fried! Firewire connection carries 30 volts, and if this connect to the wrong pins - pop goes the board. It's a £300 job to fix (I think). But first of all try pairing down any patching / connection to other equipement to a minimum to ensure that there is not something else in the chain that could be causing the problem.
Posted on Oct 14, 2010
SONY DSR PD 170 OR 170P IS THE CAMERA MODEL AND LAPTOP IS SONY VAIO VPCEG18FG. The camera has a DV firewire port and lap top has only 3 usb ports. I tried connecting it with a cable that ha s firewire...
This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
Nov 13, 2011 | Video Cameras
My DSR 45 Firewire port is fried. Any idea which Problem with the Sony DSR-45 Mini DV VCR
DSR-45's firewire port is held on a separate littlle circuit board, easily reached from the underside of the deck. Remove the bottom panel, unplug the cable from the Firewire board and there is 1 screw to hold the firewire board in place. The part is called DV-032 on Sony's Parts website and costs about £30 UK including postage to buy.
Sep 16, 2011 | Sony DSR-45 Mini DV VCR
DSR-1500
As far as I know, the deck you mention has a firewire port as standard.
Jan 07, 2010 | Sony DSR-1500 Mini DV VCR
Firewire will not work
most common problem associated with failure of firewire on the DSR-25 involves replacement of a circuit board which costs about $500.00.
Jul 01, 2009 | Sony DSR-25 Mini DV VCR
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony DSR-45 Lost Firewire Signal
Port's fried for sure -- that's a classic Firewire Port Burnout problem. Could be a cheap repair if you can take it to someone who's not afraid to get their hands dirty (soldering, perhaps). I don't know how integrated the port is to the unit (like on a laptop) so good luck!
Aug 24, 2007 | Sony DSR-45 Mini DV VCR
DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. http://forums.creativecow.net/readpost/35/856108 It has helped me
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-1500 Mini DV VCR Logo
286 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
