Television my tv turns on and turns off every few minutes. the power buttons blinks.
SOURCE: Green LIght Blinking
replace the DM or have someone repair the DM. The capacitors are bad and someone who knows how to repair circuit boards can replace them
Posted on Nov 06, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Posted on Dec 05, 2008
ginko
  • 19396 Answers
SOURCE: JVC TV Front panel power button blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
freetek
  • 5568 Answers
SOURCE: Lamp light blinking, Power Light blinking, TV off
Your description of the problem points to a power supply in the process of failing.
If it was mine, I would leave the set unplugged overnight, remove the back panel of the set, locate the power supply (likely on a separate board related to the incoming AC cable and will have larger components on it), look for an assembly number (often on a printed label), contact the manufacturer's service company and inquire about replacement or repair cost.
When you plug it back in, note whether it behaves normally at first turn-on. If is does, this tends to support the suspicion of a failing power supply since some of the passive components in it have had a chance to recover before weakening again.
Modern supplies are a good bit more efficient than 'linear' supplies of yore but are far more complex and much more dependent on quality of components.
Posted on Jul 28, 2009
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Red led blinking. tv wont turn on model number
Hi Rick,
First of all, thank you for posting your question here at Fixya.
My first advice is to unplug the unit from the outlet at least 30 minutes to reset itself and check if the symptoms still persists. If yes, may I know if it encountered before then there's some instances that the unit will power up after a few minutes of pressing the power button key?
Also, please double check the model number of your unit, if I'm not mistaken, it is 50H81 not 50H87.
Jdvillanueva
Jan 21, 2012 | Toshiba Televison & Video
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
Aug 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Trouble turning on
Try pushing the Imput and Menu buttons in together on the set and hold for 5 minutes and see if it blinks out a two digit code. Then let me know. Also these sets have a tendency to have some faulty capacitors on the DM board. Hope this helps youout.
Jan 06, 2008 | Mitsubishi WD-57732 Projection Television
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
