Question about Copystar CS-4035 Copier
Copystar CS-C2525E. Paper Jam error 91. No paper
Copystar CS-C2525E. Paper Jam error 91. No paper jam and cannot get it to clear out of Paper Jam screen. Have any solutions
    Guru:
  • 389 Answers
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Posted on Oct 08, 2009
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Depending on which paper tray you select, one of two error message is flashing on the readout: E70 or -A4. We cannot detect a paper jam. What do these codes mean and how do we correct it?
the error means that the size of the original does not match the size in the paper tray. select the tray you want use withe paper select key then make your copies
Feb 14, 2011 | Copystar CS-1500 Copier
Installed upper & Lower Fuser, Turn Copier on saying paper jam 03
its not really a jam, its the cover you have to play with it on order to lock well.
May 31, 2009 | Kyocera Copystar CS-1820 Black and White...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-1815 reports a paper jam at the document processor
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Apr 23, 2009 | Copystar CS-1815 Printer
Code e70 on copystar 1810
Jam code 70 means: No origional feed. Paper is detected on the doc feedr tray, but when the start button is pushed - the origional don't feed through.
Mar 12, 2009 | Copystar CS-1810 Copier
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
254 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
