Question about John Deere Garden
The drive belt on my 757 ztrac mower keeps coming off. I have replaced the bearings in the idler pulley, but the belt continues to come off.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Check to see if the idler arm at rear of machine where belt comes off PTO is bent or bushings wore out.Ask your dealer if there is any guides you can install around spindle pulleys.
Posted on Nov 13, 2009
Cant keep a belt on it have burnt 2 up with only 37.1 hrs on the tractor
Hello Donald, I would check any idler pulley bearing , tensioner pulley bearing, or mower deck bearings that runs on that belt. You might have a bad bearing causing the belt to burn off. Also check pulley alignment .
Aug 03, 2015 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
How do you know when your pulleys are worn out
Really what the original intended purpose was. Most times you will see the wear pattern.
On mower most v-belt idlers have the back of the belt no deeper than the outside diameter. Engine pulleys vary. If the pulley shows of the belt bottoming out in groove it either worn out, wrong pulley or wrong belt. Flat idler wear similarly just not as noticeable. Most times it is retaining lips or bearings that goes. cIt is the same v-idler when it comes to bearings.
Apr 23, 2015 | Garden
I replaced my PTO drive belt (engine to blades, part #754-0497) without any trouble.
Check all idler pulley bearings, double pulley bearings and the spindles bearings. If any feel rough hand turning replace them. Also make the spindle belt is correctly routed. Edited adding the word "belt"
The 60.5" belt is the correct for the G deck that uses the 66.5" spindle deck belt.
Apr 05, 2015 | Garden
How do i replace drive belt on husqvarna zero turn model#96645580
To replace EZT belt
Park the mower on a level surface. Engage the park brake.
EZT belt removal
NOTE: Be careful not to damage the fan blades on the EZT as this can affect cooling or damage the EZT.
  1. Remove the deck belt
  2. Create slack in the belt by pushing the spring loaded idler arm away from the belt.
  3. Rotate arm to release belt tension.
  4. The belt should now be able to be removed from the engine pulley and EZT pulleys.
Belt installation
  1. Wrap the EZT belt around the EZT pulleys.
  2. Wrap the belt around the engine pulley.
  3. Route the belt around the inside of the idler pulley while keeping tension off the belt and then slowly the idler assembly afterwards.
  4. Check that the belt is on all the pulleys correctly and test drive your unit.
  5. Afterward then re-install your mower deck once your are satisfied with the drive installation..
Feb 18, 2015 | Husqvarna Garden
Cub cadet SLT 1554 keeps throwing the drive belt
Double check the routing diagram. Check to make sure your idler pulleys are in good condition. Bearings are good. Lastly the tension spring may be worn. The belt should fit very snug. No more than 1 1/2" of deflection when you push on the belt with your thumb
Oct 15, 2012 | Garden
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
May 15, 2009 | Garden
I have a stx38 riding lawnmower. The drive is herky jerky in forw
I have seen this problem on other tractors. It is caused by a loose or sticking drive belt between the engine drive pulley and the transmission. There is an idler pulley between them that is spring loaded to keep the belt tight. If the pulley bearings froze so the pulley doesn't spin, or if rust or a broken spring prevents the pulley from swinging over enough to keep the belt tight it would cause the problem.
May 05, 2009 | John Deere Garden
Garden Logo
737 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
