Question about Motorola Mobility RAZR V3
Display not working , key pad working. able to answer calls..
  • 52 Answers
Your mobile ic probilem ic fused you can get ic an set it
Posted on Oct 06, 2009
How do i forward my phone calls
HOPE THIS HELPS:
Call Forward • The first handset (HS1) can forward an external call to another handset (HS2, HS3, or HS4) by pressing and holding the INTERCOM key. After entering the handset number to which you want to forward the call, HS1 will display CALL FORWARDED. • To answer the call, another system handset can press PHONE, SPEAKER or any dial pad keys.
NOTE: If the other HS2 does not respond within 30 seconds, the external call will be returned to HS1 and its display will show CALL BACK. If the returned call is not answered within 30 seconds, the external call will end automatically
THE MANUAL CAN BE FOUND HERE: http://dl.owneriq.net/c/c72cee7d-bd52-42c1-b9fa-2ee5ccc500af.pdf
Jun 27, 2011 | AT&T E5630 Cordless Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't answer calls key pad wont work to answer incoming calls
i think its ur key pad problem. it may be disconnected from ur circuit for many reason. 1st is under the button there r too much dust. so i cann't connect with ur pda circuit. 2nd is may be key pad has broken for pressing hardly or use many days. so u need to go tecnication . thanks
Jul 29, 2009 | Computers & Internet
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
My display screen is black, but I can recieve calls and the key pad lights up
my display is nt working bt the other functions is used.plz help
Apr 25, 2009 | LG Shine KE970 Cellular Phone
Nokia 6300 key pad not working
Solution 1.Any time your phones gets wet or by accident the phone falls off in a pool of water the best remedy is to take the batteries off immediately, don't turn the power key on, and wait for 24 hours for the phone to dry out completely.
Solution 2. Alternate solution is go to settings,select call,select anykey answer, this way u won't need the answer key any more,
Solution 3. Change the keypad,go to the nokia service center.
Apr 24, 2009 | Nokia 6300 Cellular Phone
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Keypard problem
this problem comes due to moisture so 1st of all wash the keypad with actone. and dry it. yet it don't work than check the keypad ic.
Dec 28, 2006 | Nokia 6230
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
