Question about Hilti 3431126 SF 144-A CPC Drill/Driver
Hilti te92 starts up then stops after a little use
Hilti te92 starts up then stops it is a hammer drill
    Scholar:
  • Hilti Expert
  • 123 Answers
It could be the contacts on the switch are burning out. The 92 also had an electronic speed regulator that could be going out.
After you run the drill and it stops. Unplug the drill, take the handle off and apart. Feel the screws on the switch were the wires are connected. If one of them is hot to the touch that usually means the contacts are burning up.
Posted on Oct 29, 2009
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
How to fix hilti t25 not hammering
there is a knob on it that you turn to drill or hammer ,
Nov 01, 2015 | Hilti Drills
Hilti TE 905 AVR wont hammer
sounds like it needs a rebuild kit. Hilti.com for parts or to contact Hilti to see if you can get parts. It will also have the parts breakdown.
Feb 21, 2014 | Drills
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
My Hilti Te 52 hammers hard for a minute and then stops. The motor keeps turning, if you lift slightly on the bit it'll start hammering again. After another 20 seconds it'll stop again. You can drill a...
It does sound like the clutch is worn out. You would have to completely disassemble the whole tool just to get to the clutch. Then there are no parts available.
While the 52 was a very good drill the clutch had a tendency to wear out. I know it is hard to give up on a tool that is still working halfway, but the tools made today are much faster than the 52.
PS if you look to purchase a new one from Hilti they always offer a trade on your old one.
Apr 03, 2010 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
I have a te72 hilti and i need the plece roller No 72139 help.
This is a problem we have encountered many times. There is usually a good supply of Hilti for sale used. See if you can find a drill the same as yours and swap out the parts.
Apr 24, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti 3431126 SF 144-A CPC Drill/Driver Logo
993 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
