Question about Microsoft Xbox 360 Console
My game will not load when my hard drive is attached to me xbox
    Problem Solver:
  • 10 Answers
Try to use a tall swab to get the dirt inside of the xbox with a dab of acohhol
Posted on Oct 06, 2009
How can I make my Xbox games load faster? One of my friends always loads way before us.
You can make games load faster on the Xbox 360 by installing it to your hard drive. Loading times are reduced because reading from pre-installed content on a hard drive is way faster than reading from a DVD disc. Installing is easy. Go to the dashboard, and scroll to where you would normally start the game from. But instead of pressing A to play the game, press Y on it and you should have the option to install it.
Apr 10, 2011 | Video Game Consoles & Games
Xbox is giving me an error message E68
This is a problem with the hard drive. It could be the connection is loose, a faulty hard drive, or overheating issues with the HD. Try to remove the hard-drive and attach it back again. Or if you have a spare hard drive, attach it and test.
Sep 08, 2010 | Microsoft Xbox 360 Console
My xbox 360 arcade system will not allow me to play origonal xbox games even with an xbox 360 hard drive attached
Okay, the Xbox 360 isn't reverse compatable, meaning you can't play regular xbox 360 games on it. The only version that is reverse compatable is the Xbox 360 Elite. SOrry :(
Aug 05, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
My xbox wont load up without a hard drive attached. It gives me a system error code about not having the hard drive attached and wont read that I have a memory card plugged in.
Thats right the hard drive contains the Brain program without that NOTHING will work, as it doesn't have it's instructions on the hard drive?? With NO hard drive NOTHING will ever work?
Mar 01, 2010 | Microsoft Xbox 360 Console
When turn on power button shows up red and can't play any games
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console.2.
Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive3.
Reattach the hard drive, and then turn on the console.4.
Obtain the latest automatic update for the Xbox 3602.gif. To do this, connect to Xbox Live.5.
If you continue to experience this behavior, contact Xbox Customer Service.
Nov 23, 2009 | Microsoft Xbox 360 Console
Loading Issues w/ Fable 2 After New Downloads
This could be caused by the save file, have you tried to use the game without your old save on? If you have, you may need to contact microsoft live support for more help.
Jul 28, 2009 | Microsoft Fable 2 for Xbox 360
Xbox 360 Arcade Version compatable with older games?
Yes, it either doesnt work, or the game your using isnt compatible period.
Dec 31, 2007 | Microsoft Xbox 360 Console
Red rings of death
E79: Hard Drive Error. It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and re-attach it.
Check here for more thing to try
Nov 04, 2007 | Microsoft Xbox 360 Console
Freezing during oblivian
Oblivion uses the Xbox 360 hard drive to cache game data and in some cases the info stored on the hard drive can get fragmented, slowing down the game's performance. Bethesda has already found out a way to fix the issue. Here is the official word: Oblivion uses the Xbox 360 hard drive extensively to cache (copy and reuse) game data. This is done to optimize all loading the game does. It has been found in rare cases on some Xbox 360s that the cached data can get overly fragmented. This exhibits itself by the game taking a long time to load anything from menus, dialogue, sounds, objects, levels, and more. To solve this problem, reset your Xbox, and hold down the A button as the game is booting up. If any button is held while Oblivion is loading, it will clear its hard drive cache, and create a new one. Once you see the ?Bethesda Softworks? logo video, the game is already loaded, and the cache should have been cleared. Note, this does not effect your game in any way other than loading. You will not lose any saved data.
Jul 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
