Question about Sub-Zero 632 / S
Describe how to replace a solenoid valve on a subzero 532
Describe how to replace a solenoid valve on a sub zero 532
  • 71 Answers
Easy.. disconect power . important. remove the kick plate. the water valve is locate in the left side. its a blue color. inside a bracket or attached whit 2 screws ( depend on the serial break) remove the water valve from bracket. disconect the plug and the and the line and thats all.............................................. NOTE. MAKE SURE TURN THR WATER SUPLY MOST LIKELY IS THE COOPER LINE . CLOSE FROM THE WATER METER OUSIDE YOUR HOUSE OR CLOSE TO THE WATER VALVE....... DO NOT TRY TO REMOVE THE FRIDGE.............. good luck... LEAVE YOR COMMENT IF IT WAS GOOD FOR YOU... THANKS
Posted on Apr 02, 2010
I have a sub zero 690/F refridgerator and need to get a new ice maker motor, water valve and fridge gasket can you help me?
Dear yilsu,
Parts can be ordered through our Regional Factory Certified Parts Distributors. They will need your model and serial number in order to properly assist you. You will find their contact information by following the link to our Locator. Select 'Service, Repair and Parts', enter your zip/postal code and you will receive a listing for the Factory Certified Parts Distributor for your area.
http://www.subzero.com/locator/locator.aspx
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Jan 16, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 532 refridge cooling but freezer won't freeze
Unit has separate compressors and thermostat's. Clean the condenser, if it doesn't improve call for service, as there is a decent chance you will need sealed system work or defrost issue. If you need instructions on cleaning the condenser check subzero.com.also try advanceing the defrost timer as they mostly die in the defrost cycle. Behind the grille there will be a panel with a small hole in it with a screw above and below. Use a flat blde screw driver to turn the gray piece in th small hole clockwise a few clicks. If the freezer comes back on you will need to replace the defrost timer.
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Nov 30, 2008 | Sub-Zero 561 / F
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Need panel sizes for a 532
www.subzero.com or call 800-222-7820 for the specs.
Oct 17, 2008 | Sub-Zero 632 / S
Subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Jul 30, 2008 | Sub-Zero 632 / S
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
647 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
