Question about HP LaserJet 3700n Printer
How to configure hp 3700n to print black and white only. I have tried the settings in the printer advanced configuration but not holding.
  • HP Expert
  • 217 Answers
Open printer preferences, then go to color management, use manual settings, choose black only...good luck!
Posted on Oct 06, 2009
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
I have HP 3700n color printer.
Your print driver is set to store the print job. Unless you have updated the amount of memory that your printer has, most 3700 series do not have enough memory to do this. Check your printer settings closely. Right click on the printer icon in the control panel and select properties. Click the advanced tab and then click on printing defaults and you will see a tab called Job Storage. Make it is turned off and then apply. This should solve your problem.
Aug 15, 2014 | HP Color Laser 3700N Printer
Change ip address on hp 3700n
Hello Earl Gunnerson,
Welcome, and thank you for using FixYa!
To answer your question: Copy the link I have provided below. It is a PDF file that will display in your Web Browser and will assist you in configuration of the Network settings for your printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00193141/c00193141.pdf
Have a great day!
Oct 21, 2011 | HP LaserJet 3700n Printer
Where to find the meter reading of Ricoh SP3300DN printer?
Hello!
You need to print a configuration page.
Press and hold the Cancel button for about 5 seconds.
A configuration page prints out.
Aug 05, 2011 | Ricoh Aficio MP 161 Black and White Copier
Hi. I need to make default setting to print grayscale. Kindly give me the steps. Thanks
Color/black mix
This item allows you to configure printer settings to optimize printer and cartridge performance for the printing environment. If the printer is primarily used for black printing (over two-thirds of the pages are black only), change the printer settings to MOSTLY BLACK PAGES.
Setting the color/black mix
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight SYSTEM SETUP.
5. Press to select SYSTEM SETUP.
6. Press to highlight COLOR/BLACK MIX.
7. Press to select COLOR/BLACK MIX.
8. Press or to select the desired option. (Select MOSTLY BLACK PAGES)
9. Press to select the option.
10. Press Menu.
Select MOSTLY BLACK PAGES if you print mostly monochrome print jobs, or a combination of color and monochrome print jobs.
Product User Manual (You may like to refer to Page 65)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 4700 Printer
Colour photos on my pc print out in black and white
Sounds like your photo program in configured wrong, The printer will draw it's setting from the default printer for the program and if you have the photo program set up to print in black and white then this is what the printer is going to do. Check the settings in your photo management software and see what they are
Jun 16, 2010 | HP Pavillion a818n Desktop PC (Refurb)...
The printer will not print in color. It is attach...
Update the driver under.
go to the printers folder/right click on the printer icon/ printer properties/device settings/ device type change it to color/ and apply
try printing a test page if the win logo is in color you are good to go. if the printer is still printing in black and white go to the advanced tab and under automatic configuration select update now
Al
Eliteprintersolutions@gmail.com
May 21, 2010 | HP laserjet Cp2025dn color Card Printer
Printer print only black while all cartridges are
Check your printer configuration and make sure you haven't mistakenly set it to monochrome (black and white).
Nov 27, 2009 | HP Color LaserJet 2600n Printer
How do I print configuration in Bizhub 250?
Touch utility button then on the touchscreen hit in the following order User Settings, printer settings, print reports, configuration page, and the start button
Oct 02, 2009 | Minolta bizhub 250 Black and White Copier
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3700n Printer Logo
236 people viewed this question
Seeker5211
Seeker5211
