Question about Tatung V30DMTT 29.6 in. LCD Television
Power supply problem
I am an electronics tech....i have a Tatung 2 year old 27" LCD tv and a power failure in my area caused the power supply to fail. it is part number 6693006610. can you tell me how much is a replacement? or is a simple component failure in the supply that goes bad with a power surge? thank you....bob phillips. thewiz7777@comcast.net
  • Jim Krause May 11, 2010
    If your a tech, tell me what you have checked so far? Then I can help you.
  • 3 Answers
Yo can get new psu from charles hyde
Posted on Mar 31, 2010
    Scholar:
  • 102 Answers
As an electronics tech, you should know that replacement part information can only be obtained from the original manufactuer. A public "fix-it" forum is the least likely place for such specific information.
Have you tried asking at the supermarket? Of course not.
Posted on Oct 06, 2009
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
The power light blinks blue, no screen, unable to turn on or off.
Hi Lewis,
Your tv needs to be checked by a TV tech. There is nothing you can do about it unless you are handy with electronic repairs.
May 20, 2015 | Sceptre Komodo X37SV 37 in. LCD Television
Sharp LCD tv canno power up
Power Supply Board might have several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Jun 07, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Tatung lcd flat screen monitor tv. The television comes on there is sound but the screen is black. The tv is 5 years old. What would cause this?
Failed backlight inverter circuits or the power supply for the backlight circuits has failed, you need to open it up and inspect the power suply first, look for bad caps with leaking/bulging tops. Post back what you find so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Tatung V27DMTT LCD TV (Evesham badged - UK) will not power up.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 15, 2017 | Tatung V27DMBX 27 in. LCD Television
2 year old turned tv on/off several times - TV doesn't turn on
The main power supply is in the protect mode. Usually this is caused by the high voltage section, scan amplifiers, and or the main power supply failing. Many times, when there are failures in the scan amplifier output sections, the main power supply can also be damaged.
On rare occastions, the CRT electron-gun can have a short, and cause this type of failure condition.
An experienced TV tech should be able to service this for you.
Jerry G.
May 25, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Emprex 32 in lcd power module
I got new power supply for my Emprex 3201 LCD TV for $60.00 from BTC send email to RMA
BTC RMA Department Tel: (510) 657-3956 opt. 4 for RMA FAX: (510) 657-0879 E-mail: RMA@btcusa.com
May 20, 2008 | Tatung V30DMTT 29.6 in. LCD Television
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Tatung V30DMTT 29.6 in. LCD Television Logo
399 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
