Question about Kenwood Audio Players & Recorders
When switching on system, it makes loud buzzing sound from amplifier? UK 240v
    President:
  • 1,653 Answers
Unplug everything apart from the speakers that is plugged in to the amp and check the wiring of all the connectors. If the buzzing stops when you do so then it is most likely one of the input connectors or cables causing the problem and it is most likely that the shield or earthing wire in one of those cables is aft faulty and needs repairing or replacing. If the buzzing continues try switching the input selector to something else to see if it disappears. If it does then the input channel that causes the buzzing may be faulty and need repairing and if it does not then the amp itself has an issue and will need repairing. In this case it may be a faulty power supply, preamp or main amp module especially if it comes from both or all channels.
Posted on Oct 06, 2009
Testimonial: "Thanks. It looks like a major fault in the main amp unit."
Buzzing sound
Has bad amplifier module. cheaper to replace chair.
Dec 26, 2013 | Comfort Research Marvel Avengers Vybe...
Loud buzzing sound
Amp is shot. Will need to be replaced. Not an uncommon complaint on this model.
Dec 02, 2013 | Mirage OMNI S8 Speaker
Buzzing sound car stereo
A lound buzzing sound is an indication that the Driver (transistor) for the amplifier final is bad. This is not so much a buzzing and it is extreme in loundness.
May 05, 2013 | Chrysler concorde amplifier. radio. ....
My NSM Prestige 2 makes an electrical buzzing noise at the top left corner?
i may be wrong but take the bulb out and see if the bulb may be buzzing also if you have a stereo / mono switch on the jukebox switch to the other function on my rock ola did this i switch it from stereo to mono the humming stop i hope not but your amplifier may be going out i know mine is going bad and they are not cheap
Dec 20, 2012 | Audio Players & Recorders
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
I have a Rowe AMI 100CD jukebox. Its making a loud buzzing noise when I plug it in. Everything else works except the loud noise that I have to unplug it right sway. Do you think it is the red button fuse,...
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
Feb 21, 2010 | Wurlitzer Jukebox 1015 One More Time...
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My azur 540a/640a v2.0 amplifier is not working.
Loud buzzing normally means dc on output or through your spaeker,amplifier needs to be serviced as it is faulty
Dec 25, 2008 | Cambridge Audio Azur 540A Amplifier
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
May 04, 2008 | Onkyo TX-SR875 Receiver
149 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
