Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Dyson My Dyson DC04 runs for a second or two then stops. I have checked the motor. The brushes are good but the commutator is a slightly pitted.Do I need a new motor?
  • 372 Answers
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
Posted on Dec 23, 2007
Smelly Dyson DC04
Hi Philip,
I'm sorry to hear you're having difficulties with your DC04. If the machine's making an unusual smell, we'd advise against running it again. I'd encourage you to get in touch with us directly so we can help resolve this.
You can call us on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 10, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dc04 absolute brush bar wont turn
Hi Tracy,
I'm sorry to hear you're having difficulties with your DC04 Absolute. If the brushbar won't turn, I'd encourage you to give us a call so we can run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
http://www.dyson.co.uk/support
Jan 13, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson DC04 brush control and it sometimes jumps of the carpet on the back stroke when vacuuming. I have checked the belts and the brush and all seems well. Could this be wear and tear on the...
Sorry to hear you're having difficulties with your DC04. You might find it helpful to run through this step-by-step troubleshooting guide to make sure the soleplate is correctly fitted, and that there are no blockages in the cleaner:
http://www.dyson.co.uk/support/help.asp?article=89&product=DC04-SY-STD-BC
If you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Customer Service
Aug 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
HI , I REPLACED MOTOR BRUSHES ,BUT MOTOR IS MAKING A FUNNY NOISE ,AS IF MOTOR IS LOOSING CONTACT ,LIKE A BURNING SMELL. CHEERS
Most likely you have a damaged commutator. I used to change the brushes on the dyson vacuums but what i found is that it is almost never completely successful. THe Dyson motor is not as good quality as say a miele and when the brushes go they normally cause damage to the commutator. THe best bet is to replace the motor. If you were able to swap the brushes a motor change will be easy for you. If you are in Australia you can get the motors from VacuumSpot or Nelson Vacuums.
Dec 25, 2010 | Dyson DC08 Cylinder Bagless Canister...
When running it makes a very loud quite high pitched long clicking sound . What can I do about it as I do not want to continue to use it like this
If the noise is continuous from switching on and slows down to a stop when machine is tured of it has to be some thing on contact with the motor or the brush roller the brush roller is easy to check the motor isnt but is less likly to go wrong
Jul 25, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
May 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
DYSON MOTOR BRUSHES
how do I change the carbon brushes in a dc07, I have removed the brush units from the motor
Nov 20, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Why does my dyson dc04 work for about 5 mins then cut out
I spent 4 years working on Dyson v/ceaners in the Uk
So, heres what to;
Check your filters - and for blokages in the hose and brush comparments,you have one in at top of the bucket called pre motor filter and one on top of the motor where the bucket sits called post motor filter. If these are worn and mucky wash them or replace.
Switch on your Dyson with no filters in and leave running to see if it cuts out. (in side on the motor their a liitle device called a TOC thermal over load cut out device. when the motor runs too warm - the TOC with cut power to the motor and will work again when cooled down.
Good luck.
Mar 18, 2008 | Vacuums
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
265 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
