Bios does not save any changes that are made toshiba sat.
Toshiba satellite u205-s5057 trying to change the boot order and when i push end to save all changes nothing happens nothing !
im trying to reload xp and getting the missing ntldr messege
  • 591 Answers
Changes to Boot Order only last as long as the next boot, you have to press F12 every time to alter boot sequence.
Posted on Oct 06, 2009
Satellite u205-s5057 freezes up when online.
Sounds like a bug. Download and install CCleaner and Malewarebytes from CNET. Run CCleaner first, both the Cleaner and Registry, then Malewarebytes on a Quick Scan. If there is a Java or Adobe Flash bug in the laptop, Malewarebytes will find them.
Your not done yet!
Download TDSSKiller for Kaspersky. You can find it on Google and at CNET. Run TDSSkiller and make sure there are no root kits. When you are done with that, make sure you have all your Microsoft, Java and Adobe Updates then Run a Full Scan with Malewarebytes.
Please post how this works out for you.
Jan 18, 2014 | Toshiba Satellite U205-S5057 Laptop AC...
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Toshiba u205 - SD card won't stay in reader
Just buy an external SD card reader that plugs into one of your usb ports. You should be able to get one at any local pc shop or best buy.
Aug 17, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Hi.I just forgot my bios password.the laptop dosent allow me to change the operating disk when i turn it on.it just want a password. Model: Toshiba U205-s5022
open your laptor, plug off bios bettery, then plun in again, that will reset bios password
i hope this helpfull
please rate my answer
thanks for using fixya
Dec 09, 2010 | Toshiba Satellite U205-S5002 Notebook
Cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
May 10, 2009 | Toshiba Satellite U205-S5002 Notebook
Hard Disk Sound
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Sep 17, 2007 | Toshiba Satellite U205 Notebook
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
