Question about Dell 5210n Laser Printer
SOURCE: Dell 944 All-in-One Printer - printhead carrier jam
I opened my printer while it was on and turned it off. As the carrier moved over and came into view, I found the problem. it had popped open, so I simply had to close it. Then, my printer worked again.
Posted on Jan 19, 2008
I used the menu on the printer to select change print cartridge and pretended to change the cartridge. Then I aligned the cartridge and that seemed to work for me. I wish Dell would have elaborated on how to clear a "carrier jam." I'm glad others have had this problem and were able to fix it too!
Posted on May 30, 2008
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
SOURCE: Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Posted on Jun 07, 2009
SOURCE: 933.00 Service Printhead Error
take the toner out and shake it or try to replace it with a new one
Posted on Jul 21, 2009
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
Dec 07, 2009 | HP Designjet T1100ps Printer
Nov 17, 2009 | Kodak ESP 5 Printer
Oct 20, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Oct 01, 2009 | Canon S400 InkJet Printer
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
Jul 21, 2009 | IBM Infoprint 1572 Laser Printer
Jul 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
437 people viewed this question
