Beko washing machine WMA641W. Door won't open after washing cycle complete. Fidling with controls can eventually release latch, but hours after wash ends
5 Suggested Answers
  • 44 Answers
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Posted on Mar 22, 2009
  • 24 Answers
SOURCE: just change brushers on beko wma641w and now water
make sure you have a circut through the brushes
Posted on Aug 05, 2009
  • 36 Answers
SOURCE: BEKO WMA641W washing machine not draining but pump
Are you sure the pump is working, or it the motor thats running? If the pump is truly working, there is a clog in pump or line. If the motor is working, but the pump is not, you will need to replace. You can usually buy a replacement pump for the washing machine for around $50. They are usually easy to install for a beginner DYI. Make sure you know the easiest way to remove washing machine housing to get at pump and motor. Unplug entire unit. Remove 2 hoses for pump and either screws or brackets to remove housing. BTW if the washing machine won't drain, you are going to have a bunch of water that gravity wants to dump out of machine. Bring pump to parts dealer for exact match.
Posted on Aug 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
Why is the Washing machine door does not open?
The door latch is normally locked by a relay whilst the washing machine is operating to avoid accidental door opening and flooding. Once the wash is complete a timer operates and releases the door latch relay to allow door opening. The relay must have stuck. Try to turn off the mains power supply to washer and if you hear a click then relay has released and the door should open. But if no difference then the relay or latch is jammed and you will have to use a mild force with a blunt screw driver to force open the door. If this is hard then take the washing machine cover top cover out and access the switch from side. Make sure the mains power cable is taken out.
Aug 02, 2014 | Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Beko wma641w wont spin?
Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 24, 2013 | Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    Door wont open
    It ispossible that the program has not concluded or there is an error on the controller that has not completed the cycle and so released the doorr latch.
    You must reset the timer and see if the latch is released, if not the controller can be faulty.
    Also check the links and latch mechanism as this can get stuck up on its own.Use a degreasing sprqay like WD 40 to remove any jam on the lock mechanism.
    Jul 07, 2011 | Ariston Technologies AWD 121
    I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
    those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
    Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    LD WD1238C Door is Locked shut tried every trick you can think of including giving it a little kick
    often on the upper grade washing machines, the components are a little more sophisticated. Possibly once you have removed the top lid, you will see the door latch from the back. some of the latches have a drawstring that you can pull which mechanically releases the door and opens. If you are able to before getting into stripping the wachine, gie it a quick cycle run and let it complete the cycle, Then try and open it. go from there.
    May 19, 2010 | LG WD-1280FHD Front Load Washer
    Washer will not open after washing cycle ie
    Hi:
    There is a door locking mechanism that won't let you open the door during certain cycles, and it might be hanging up. After the next time the door sticks, try gently tapping on the door , near the latch area. If the door releases, you need to get that solenoid replaced,
    Nov 03, 2009 | Equator EZ 3600 CEE Front Load Washer /...
    Beko wma641w reset
    hi
    regards
    Mar 22, 2009 | Washing Machines
    Washing Machines Logo
    783 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
