Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
APC Back-UPS ES 350 - when powered on has a blinking green light Is this normal
  • 28 Answers
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here: http://www.batteryinternational.com/apc-backups-es-be350u-ups-battery-ups-batteries-f1.html
Posted on Feb 12, 2010
Blinking red and green lights
Check battery and charging voltages. APC says 90% of faults are a dead battery. My experience also
Oct 15, 2014 | APC Products - APC - Back-UPS ES 750...
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Need charging instructions for apc back-ups es 350
Take off the bottom cover and make sure the battery is connected (both terminals).
Plug the unit into a wall outlet.
Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
Done.
Aug 08, 2009 | APC Back-UPS ES 350 UPS System
APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
May 27, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC UPS issues
If its really a noise? neutral and ground of your utility power (building transformer) should be bonded
Apr 14, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
1,265 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
