Question about Kenmore 63942 Dryer
Dryer turns on but the drum will not turn
I set the timer it works. light comes on but the drum will not turn. the belt is still on.
  • 496 Answers
Have you checked to see if the belt is loose? If it is tight and still routed correctly around the drum, motor and tensioning arm, I would suspect your motor needs replacing.
Hope this helps...
Posted on Oct 06, 2009
When i turn the dryer on a setting, I get a humming noise and the drum does not turn. (maytag)
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove
the drum and belt and this will expose the drum rollers, idler arm bracket
with pulley, and motor with pulley. Pay attention to the route of the belt,
this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum
not to turn.
While you have the drum out, I would recommend that you lubricate the drum
rollers at the shaft of the roller with a good grade of machine oil like 3
in One oil. This will save you a problem later with the rollers getting
noisy, also check your drum rollers for flat spots, if they have flat spots
on them this will cause a noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Free answer...Please rate me
Dec 04, 2010 | Maytag Dryers
I have a Frigidaire LEQ2152ES Electric Dryer. The light comes on when you open the door. And the lights and sounds come on when you push the settings. Push the start button, and you hear the tick for...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Electric dryer will not tumble. No noise at all when top start/s
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 24, 2010 | Whirlpool WED5100SQ Front-Load Electric...
I have a Kenmore Elite HE3. The drum suddenly stopped turning. The timer works but the dryer makes no noise or turns.
Good luck,
I hope this helps
Thank you
May 15, 2010 | Dryers
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
When i turn the dryer on it makes a humming noise but it does not turn on all the way to start- does not start but don't sound like the motor, maybe a sensor? i cleaned out the lent trap..the only light...
Good luck,
I hope this helps
Nov 10, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My kenmore elite dryer doesn't turn on at all. I know that electricity is getting to it because the light turns on inside. What is wrong w/ my dryer
Good luck,
I hope this helps
Nov 03, 2009 | Kenmore Dryers
DRYER WON'T SPIN, DRYER TURNS ON, BUT DOESN'T SPIN, CAN'T FIND BELTS
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Good luck,
I hope this helps
Oct 26, 2009 | Maytag Dryers
Dryer won't turn on - interior light on
It sounds like you have either a broken drum belt or a door switch that isn't working. If the dryer belt breaks, the drum will not turn, but you will probably still hear the motor running. I don't think your model has a broken belt switch that disables the motor (at least I couldn't find one). You didn't mention anything about hearing a motor running, either. The likely cause, then. would be a door switch. If the switch was not making contact when the door was closed, it would give the very same symptoms you described. Have you tried pushing on the switch with the door open to see if the drum light goes out? If the light DOES go out, we probably have a primary power problem to the drive motor. If the light DOES NOT go out, replace the door switch. You can find the part at searspartsdirect.com. Just type in your model number and you can locate the switch under the "Cabinet Parts" heading as item number 10 (part #3406107). Let me know how you diagnose this and get back to me. If it is the switch, I can give you steps on how to replace it. If its not, then we'll have to troubleshoot a little further. I'm trying the simple approach first before attempting to disassemble the dryer. I hope this helps you.
Jul 03, 2008 | Whirlpool LER5636P Electric Dryer
Dryer isn't turning
This could be one or two things, it could be the safety switch located in door that activates the turning of the dryer. Or it could be a belt that turns the drum the motor could be turning inside and belt is broken.
Aug 16, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
