Question about Denon DP-47F Turntable
The Denon dp-45f has the old red & white jacks and a ground wire however my onkyo receiver doesn't appear to have anyplace to connect the ground as I have inputed the jacks into the dvd inputs (no phono inpust on the receiver) is there a way to connect these two together completely
  • 70 Answers
Fasten the ground to one of the metal screws that hold the metal(?) cover on.You want to connect it to the metal frame of Onkyo.
Posted on Oct 06, 2009
  • 4,234 Answers
First of all, the DVD input won't work unlessyou insert a phono preamp into the mix. The preamp will bring the phono level signal up to the line level needed for the DVD input. The turntable can be grounded to the chassis of the receiver using any of the cabinet screws. The ground is necessary due to the extremely low signal levels produced by the turntable. Some of the pre-amps provide the grounding necessary at the pre-amp input as well.
Dan
    President:
  • 1,653 Answers
Most modern hifi and video based systems use the double insulated principle these days with no ground wire used. Ground wire based systems need to have all the ground wires connected to 1 single point to avoid what is known as earthing loops that can lead to serious humming problems especially in hifi systems. If no other components in your system use any earthing then you can connect the earthing on the t/t directly to your mains earthing via the mains plug that supplies the turntable. If the Onkyo is grounded via the mains then connect a piece of extension wire from the t/t and connect it to the earthing point on the rear of the Onkyo receiver.
How do I hook up my iphone 5s to my Onkyo TX-8511
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
Jan 02, 2015 | Onkyo TX-8511 Receiver
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
How to connect a walkman to a Denon AVR-3805
headphone jack cable to 2x RCA/phono (red & white) cable. Connect that to a spare input on the amp.
Sep 02, 2014 | Denon AVR-3805 Receiver
I have an Onkyo TX-8522 stereo system. I am trying to connect my iphone to it so that i can play music there (both from Pandora and from my own music from itunes). I was wondering if this was actually...
Yes it is possible. Any audio device with an earphone out jack can be connected to a receiver by using the CD input or the AUX input jacks (white and red) on the receiver. All you need is an adapter cable with the stereo 3.5mm plug on the iPhone side and the 2 RCA connectors on the receiver side. You can get these for $2 or so at Amazon.com or at Radio Shack. Adjust the volume and select on the receiver, the input you used to connect and enjoy.
http://www.amazon.com/RiteAV-3-5mm-Stereo-Male-Cable/dp/B000V0G2C4/ref=sr_1_1?ie=UTF8&qid=1306765483&sr=8-1
See above link for one example of the cable.
May 30, 2011 | Onkyo TX-8522 Receiver
Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Jan 06, 2009 | Onkyo TX-SR602 Receiver
No audio thru receiver with xbox360
Get some audio cables from radio shack or gamestop and use the regular audio jacks on the xbox to connect to your receiver.  Your video will be HD, but your audio won't.
Dec 22, 2008 | Denon AVR-1603 Receiver
Headshell for Denon DP-45F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Aug 02, 2008 | Audio Players & Recorders
Platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
Denon DP-47F Turntable Logo
818 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
