Question about Kirby Heritage II Vacuum
How do I get the case apart on my Kirby Heritage II (2HD) to replace the fan impeller? I can only find 3 screws holding it and there seems to be more.
From the rear, there are 3 screws on right and one on the lower left. There is 1 more on the front at the top just under the lamp.
You will also need to remove the safety switch - the plastic thing down and just right of the front screw. Take out the 2 screws. Pull the switch gently away from the case and try to get a look at how it's put together.
There is a bent rod inside with a plastic 'bar' holding it in. The flat end of the rod is on top - the round end at the bottom goes into a loop on a metal strip that is sticking out from the motor housing. By lifting up and wiggling, the rod will come out of the loop. Often, the plastic bar will come out and rod will just fall out. Just put the rod and the plastic bar back together (this is why you looked at it before). I tape the bar in place with Scotch tape or any thin tape and leave it that way.
The fan housing is sealed with caulking (or whatever the last person to service it used). A few raps on the side of the case with rubber mallet and/or sticking a thin putty knife in the joint should do.
You will need to scrape the joint clean and reseal it when you're done or it will blow dust like mad. Any caulking or gasket sealer will do. Just don't use high strength adhesive if you ever want to take it apart again without dynamite.
Btw, the fan pulley is a left-hand thread.
Posted on Nov 12, 2009
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the...
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Oct 05, 2009 | Kirby Heritage II Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Replacing the bearing behind fan on a kirby heiritage II 2hd
I don't know what model of Kirby you have but on all Kirby's that I know of you have to remove the fan.
Here are two vid's on fan removal for a generation series vacuum.
Feb 26, 2009 | Vacuums
Kirby fan on motor
I am assuming that you are trying to remove the fan. On newer models there is a cut on the shaft (rear of the motor - next to comutator) that allows to use a wrench to hold the armature, it may be very similar on older models. maybe a hole instead of the cut... You would have to access the rear of the motor though. Let me know if you cant find it - I'll take one Heritage apart here in the shop and will see.
Good Luck
Oct 05, 2008 | Kirby Heritage II Vacuum
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Jun 21, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
195 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
