Question about HP Office Equipment & Supplies
HP colorjet 2605dn displays ''door open'' error message and light
My HP colorjet 2605dn displays a ''door open'' error message and an orange light blinks, even though no door appears to be open.
Please help!
    Problem Solver:
  • 5 Answers
On the memory controller board (the unit inside the printer which each toner unit makes contact with. If you open the front door and remove each toner,you will see a row of 4 contacts plus 4 leds and 4 receivers, encased in a metal casing/guard), there is a small white actuator, just to the left of the black toner,which is coupled to the scanner shutter lever.
If this is not correctly coupled, it will result in the "door open" message. The white actuator should spring back out towards the front of the printer when you press with a small flat blade srewdriver and release.
I had to remove top cover, rear plate, lhs covern High voltage psu and the memory controller board. I made sure the shutter lever and the actuator were set correctly and reassmbled.
Door open message was resolved.
Posted on Dec 09, 2009
  • david64955
    david64955 Jun 11, 2012
    A picture would be helpful. Thanks anyway.
  • 23 Answers
No you dont! remove side covers, back plate, circuit board plate. 3 screws on the scanner assy, your in. compressed air and GENTLY, a foam swab.
Posted on Feb 10, 2014
geemarie
  • 876 Answers
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
Posted on Aug 15, 2008
  • 3 Answers
SOURCE: HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Posted on Sep 16, 2008
  • 22 Answers
SOURCE: hp 4215 printer
Solution Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (on button ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
if this does not work
you may need service from service centre
good lluck
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
Posted on Apr 30, 2009
  • 217 Answers
SOURCE: ETB replaced now when printer is turned on no fans
Double check EVERYTHING you disturbed when you replaced the Transfer Belt.
Probably 2 things not connected properly - fan obviously, and a sensor.
Posted on May 09, 2010
Hp laser jet 2605dn give a error 10.0000
Any 10 errors are related to cartridges and the memory chips on them. If you just changed a cartridge then it is possible that it is defective. Try putting the old cartridge back in. Also ensure that the cartridges are all seated fully and that the front door closes properly as this can trigger the error as well.
Oct 10, 2014 | HP LaserJet 2605dn Printer
I have a problem from hp laser colorjet 47OOn whith code error is 54.15
54.15 PRINTER ERRORDescription There is a problem with the Yellow CPR sensor.Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Dec 27, 2012 | HP LaserJet 4700 Printer
Hewlett Packard Laserjet 2605dn Printer: Error 79 after firmware update
HP has now admitted their firmware update causes an irreversible corruption in the formatter board. It is hard to get them to do this, but I understand they will repair at no cost if they can determine that you did install this update.
Jun 20, 2012 | HP LaserJet 2605dn Printer
ETB replaced now when printer is turned on no fans run and error message on display states paper jam in ouput bin. Looked found no paper jams.. HP CLJ 2605dn.
Jan 13, 2010 | HP LaserJet 2605DTN Color Printer
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Carriage Jam
If either a paper jam or blocked carriage error message appears on
the control panel display, there might be some packing material inside the HP allin-
one. Lift open the print-carriage access door. The orange shipping lock might
still be in place on the left side of the HP all-in-one. Pull out the orange shipping
lock and throw it away
Jan 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
1,810 people viewed this question
Seeker5211
Seeker5211
