Question about GE Refrigerators
GE Refrigerator Once a week my refrige gets warm and I have to take a heat gun and melt the ice off of the little siver things on the freezer side. Once I do that it gets cold until the ice forms again and I have to repeat the process, model # GSS20IEMB CC What can I do?
  • oglesby_jack Oct 14, 2009
    can I replace the heater?someone told me to use heat strips
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 14, 2009
  • 339 Answers
The most likely problem is the defrost heater. It could also be the defrost thermistor or there's an outside chance of it being the main control board as well. You can test the heater with a multimeter and it should have a high but measurable resistance.
Posted on Oct 08, 2009
  • 708 Answers
The rubber seal on your door us letting air and moisture into the freeze which then freezes. To verify this when you open your freezer door and close it, push it a little harder for a few days and see if this stops. This is what happened to my maytag deep freeze because we had too much stuff in the door. We took some stuff out an it stopped doing that. you may try that as well.
Posted on Oct 06, 2009
I have a Whirlpool refrig./freezer. I have no problem with the ice dropping in the bucket,but when I try to dispense it under the chute,it wil not dispense. The water works fine. This is a side side ...
Sometimes the ice will collect, melt, and freeze into a giant headache. If you have the one where you can get ice out of the holding bin inside the freezer, see if the ice bin will come apart from the rest of the dispenser. If it doesn't come easily, get as much ice out of the bin, get a wet vac ready and pour warm water on the ice. It will run through the dispenser. Once things come apart easily, you can take it over to sink and get rid of the ice blockage with warm water, let it dry, reinstall, and check to see if it works. Hope this helps.
Nov 03, 2013 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Food in refrig crispers freezes. Top of freezer too warm.
Good day,
You are right about it being little or no air circulation. There is a fan motor in the freezer, which you can access by removing the rear panel of the freezer panel.
That's the good news. The bad news it is a DC variable speed motor controlled thru a thermistor and powered from the motherboard located in the back wall of the refrigerator.
You can remove and take the motor to an appliance parts house that deals in GE parts. If they determine the motor is bad, then you could effect a repair.
If not the machine is too complex, and some parts so expensive that repair is best left to a GE qualified pro.
Nov 09, 2009 | GE Adora (DSF25KGTBG) Side by Side...
I have a profile ge freezer on bottom and the freezer is very cold and refrig is 68
check that fan is turning.
if stopped it may be from ice behind panel.
then check for defrost issues
usually bad defrost thermostat (round disc by heating coils that melt ice
Oct 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or latter...is the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer ices up- refrig and freezer starts to fail
you have a defrost problem.
the things to check are the defrost heater and thermal fuse in series with it. if these are ok, you probably have a problem with the main module
May 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
