Question about Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC
Hello i want to take my tracks and make them on to one file
Hello , i recorded 3 tracks and want to put them together on a file as a song and i dont know how to do that. please help.
    Problem Solver:
  • 18 Answers
Try to use a program called nero wave editor. What is does is allow you to cut and paste on any wav file. You can inturn just past the one song after the other.
Hope it helps.
Posted on Oct 20, 2009
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
May 25, 2015 | Fostex Mr8 Mkii Mxl 990991 Recording...
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
Jan 31, 2010 | Boss Micro BR Digital Recorder
Altering an mp3 track
hi,
If you simply want to overlap the voice, you can do that by recording using any free softwares available on internet (just google free recording softwares)
you can try, cooledit as well, one track will contain your file with play mode, one track with record mode (for your voice)
then start recording, it will play the song simultaneously with recording your voice.
After then, you have to save the mixdown.
other long way is, you have to get KARAOKE for that song (karaoke means, no vocals only music track) then you'll get the recorded song in good quality.
Hope this helps.
Thanks.
May 11, 2009 | Apple Computers & Internet
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
Recording midi player
Yes. You can record the midi output to a track using bounce mode.
With you midi (or smf) file loaded into the midi tone generator,
press shift-bounce to enter bounce mode. Then arm a track for recording. Turn the fader up for that track, the master fader and the fader for the midi tone generator. Make sure than all other track faders are down or the tracks are muted (or empty) and press play and record. The midi song will be recorded to the track in real time. Just press 'stop' when done and exit bounce mode (by pressing the bounce button again).
bd.
Jan 12, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Fostex MR8-MKII - 8 -Rack Portable Compact Flash Recorder MR8MKII for PC Logo
79 people viewed this question
Top Fostex Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Julie Clark
Julie Clark
Are you a Fostex Computer and Internet Expert? Answer questions, earn points and help others
