Question about Toshiba Satellite L10 Notebook
Child has pressed buttons on the key board and when booting up it only goes as far as the boot up screen giving the option to select F2 to enter set up or F12 for multi boot selection but when you select either it just says please wait and goes no further
    Scholar:
  • 43 Answers
It's doubtful that this issue was caused by someone pressing a key regardless of when they pressed it or their age ;) . This sounds more like a Hard Drive issue from a major virus. Make sure there are no "system" disks in the computer when turning on. Also, unplug all USB and other peripheral equipment from the computer prior to powering up. Some peripherals don't work and play well with others. There are small driver programs installed on all memory sticks (aka flash drives, thumb drives, etc.). These can cause boot-up problems as well. So, try unplugging everything that is not absolutely necessary and power up. That's your best bet and the easiest to try.
Good Luck!
Posted on Oct 06, 2009
How do i change boot order on emachine t3604
When the machine are start to boot press F2 before start windows, That is the setup of the Bios and there you can change the boot order
Feb 19, 2015 | E-Machines eMachines Desktop PC
Motherboard won't recognize hard drive. won't book from windows 7 disc
Hello you have to enter the bios option to change the bootup settings.
Press the DEL or F2 button to enter the bios.
Next select the boot option, and make the DVD drive as first boot device, harddrive second.
Leave the bios by saving the settings you just made.
Place the windows disc in the dvd drive, and reboot.
The screen turns black, and a small text comes on top:
Press any key to boot from disk, use the space button.
Now the installation will start.
Remember to format the harddrive, when prompt.
The drivers can be downloaded here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR
Best of luck
Sep 03, 2013 | Intel D945GCCR Motherboard
How can i exit safe mode on my toshiba laptop
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 02, 2012 | Toshiba Computers & Internet
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
No operating system found can't boot from usb there is no boot from usb option
Did you try pressing F8 key at boot up?
  • 1
    Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
  • 2
    Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
  • 3
    Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
  • 4
    As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
  • 5
    Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
  • Read more: How Do I Get My Toshiba to Boot From a USB? ' eHow.com http://www.ehow.com/how_5970005_do-toshiba-boot-usb_.html#ixzz1hrx9qZ3j
    Dec 28, 2011 | Toshiba Computers & Internet
    How to install change first boot divice on ibm thinkcentre computer
    You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
    Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
    BE VERY CAREFUL WHAT YOU SELECT!
    Thanks for your visit today.
    Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
    My acer 532h netbook will not boot,none of the safe modes either
    switch it on then press the key that takes it in to the BIOS or SETUP it will tell you on the start up screen, Should be "F2" when your in the bios use the arrow keys to move through the options.
    More across to exit and press enter then go down to set/get or load system defaults press enter again then save & exit & the system will re-boot.
    if it dosn't boot then do the same again but this time press the boot menu option on start up "F12" or "F8" i think, i should give you a list from the list select the hard drive & hit enter.
    Let me know what it says & i will be able to help you more.
    Sep 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
    I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
    It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
    in the bios set boot order to HD as firstboot option then save and exit
    hope this helps
    dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
    Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
    How to set boot priority in bios is thinkcentre lenovo it has no option in bios
    when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
    Oct 21, 2009 | Lenovo ThinkCentreĀ® M55-8810 PC Desktop
    Selecting booting device
    Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
    If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
    If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
    Hope it helps.
    Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
    Toshiba Satellite L10 Notebook Logo
    75 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
