Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
My Maytag wide by side is not cooling properly
For the last week my fridge has gradually stopped cooling properly, despite stepping up the cooling level (twice). Is there is something simple to do - like food blocking a vent or something - or can I easily check if the condenser is working properly. I want to decide whether I need to call someone out in an emergency since we are having 40 people over for Xmas !!!
My wife is understandably a bit panicked!
Can you help?
Thanks
Howard
  • 2 more comments
  • Anonymous Jan 04, 2008
    Evaporator coils are frozen solid. I was afraid when I saw this. I thought I had only a moment to act so I through boiling water in at the coils but I slipped and fell with the hot pot and the water burned me and my wife. I also tried to beat the ice off using my shoe, this to proved to be a useless act. Please tell me what part I need to fix this problem as I fear this could be an extremely dangerous situation.
    Thank you,
    Sol
  • Anonymous Mar 24, 2008
    5 year old wide by side 26.8 CF noticed ref. side getting warmer, increased temp guage no help. ref. side inside temp is 50 degrees. Freezer side is working properly with temps well into freeze level. I found no frost or ice looking into what appears to be the coil area in the bottom of the freezer compartment.dpreynolds2windstream.net
  • mit731213 Aug 24, 2008
    my feezer got warm everything thawed and the fridge side is warm as well. pulled off all panels and no ice formed anywhere, inside or out however, near the compresor i here a clicking noise every few minutes but cant seem to pinpoint where it is coming from. the fridge is 5 years or so old and has had other problems in the past however they were easy to fix.
  • hairkeeper1 May 04, 2009
    I bought this fridge in 2001 they replaced the ice maker twice and the compressior twice! its a joke maytag is the worst product on the market I WILL NEVER BUY ONE AGAIN> also the dish washer mother board has gone out twice and the washer and dryer are junk too!
    Problem Solver:
  • 17 Answers
Hello! No problem, Home repair or call tech.
No cooling: 1. Open the freezer section, look at the bottom, opening in the back, can you see the cooling evaporator coils, or is it white with frost. Its late to do repairs, if it is fully frosted, need to be defrosted, move food out, use hair dryer and melt frost off. Put food back and run unit, do repairs after holidays. Regards fmauka..
Posted on Dec 23, 2007
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Plus model # MSD2756AEB side by side that has been having isues with the fridge side being warm & not cooling things for the last 3 weeks. Now the freezer has stop keeping things f
HOW OLD IS THE FRIDGE?...WHEN WAS THE LAST TIME YOU PULLED IT OUT AND VACUUMED THE REAR INTAKE AND BOTTOM CONDENSER FINS....THE FRIDGE "HAS" TO BREATH TO OPERATE PROPERLY!!!
*** THE TEMPERATURE SWITCH COULD BE BAD AS WELL
Jul 30, 2012 | Refrigerators
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
663 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
