Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai 5598hdi convengence
Hi sreekidu, 1st of all thks so much 4 helping out all of us who cant afford the in person repairman. I have an akai 5598hdi. like to many other buyers, I have a contengency prob also. I bought 2 amps and replaced the old one refer:( cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html ) after the replacement/heat sink, i turned on the tv w/no results.. I was unable to do manual adjustment what so ever. I then called samsung and asked for the replacement board..they said they discontinued that board for the akai.I then asked that if so many people are having the same prob after 3-4 yrs, why would you discontinue the board? well after a bit they set me up w/J&J Inernational,Inc they had a replacement board BP95-00142E w/2 ic's stk for $96.00. Well i greatly thanked them and ordered the part..I get the board and replace the old one and still I'm unable to adjust the convergence manualy or auto... the tv remains the same as before. Am i forgetting something or is there a process? I have no svc manual and figure I've spent enough on the tv.. Pls help if u can... Happy Holidays.. email if needed:banditlee07@yahoo.com...many thks bandit
  • 3 more comments
  • ted lee sweitzer Dec 24, 2007
    Thks troylove11 for the help,if I had replaced the board w/a new one,should'nt all the fuses be good 2 go? you said(fuses open in that area)or do u mean fuses in other areas of the tv? My contengency board is a newly seperate standalone board. Its just wierd doing these changes/replacements and i cant adjust anything..thks again...
  • ted lee sweitzer Dec 26, 2007
    can anyone pls snd me the adjustment codes or svc manual pages under contengency. If I had done a factory reset on my akai some say the new contengency settings must be installed in the mem ..How do I do this and Thk you all for the help.. Bandit
  • ted lee sweitzer Dec 28, 2007
    Thks Terryfic for the help. the model #pt5598hdi..ser# 38743cex402426 thks so much..bandit
  • ted lee sweitzer Jan 02, 2008
    Thks Terryfic, My contengence board sets seperatly by a single screw above the main cir brd. The one I ordered was complete w/the two amps attatched. I just disconnected the old one and replaced it w/the new. The description as listed on the invoice:(J&J International, Inc): ASSY SUB PCB-CG AMP/WITH 2 IC'S STK: PART NUMBER BP95-00142E. COST $96.53.Reading most fixs here, they say they replaced the boards/stk's and did a manual adj.. I'm not able to do this so i assumed there is something Im not doing... most said code mute 183,adjust then save.. but nothing happens in my case. when attempting perfect focas i get (check factory data) oh after replaceing the new brd and no results, I did factory reset. hope this info helps .. well let me know I'm stumped... thks again Bandit
  • ted lee sweitzer Jan 03, 2008
    Hey Terryfic, attempted pwr off mute 183 pwr on and the tv station comes on (not service) I tried this several times w/no luck, and no I dont know step by step/ save..?? Bandit
    Genius:
  • 1,694 Answers
The B+ voltages to run the convergence originate on the main PC board,power supply area...there are soldered in fuses to be
checked with an ohmmeter.....another related procedure is to
measure voltages with a meter, but that is normally done by
a qualified tech with service manual in hand..............T.
Posted on Dec 26, 2007
  • 3 more comments
  • Vista Electronics Dec 26, 2007
    PS. Please provide complete Model / Service # 's on back of set.
  • Vista Electronics Dec 30, 2007
    Bandit,
    I verified PC board correct for your model, but I have a ?...
    What does " A REPLACEMENT BOARD ...W/ 2 IC'S..."
    mean ? Were the IC's seperate from the board or already mounted on the board ? What quality...? ..brand....?
    warranty....?......................................T.
  • Vista Electronics Jan 02, 2008
    Bandit,
    Service entry is with power off....mute 1-8-3-power on...adjust
    and save.....And I never do factory reset,usually means get the
    service lit. so you understand what to do step-by-step.....T.
  • Vista Electronics Jan 04, 2008
    Time to get the service literature....try
    manuals.electromaniacs.com ..................T.
    Try.............retrevo.com servicemanuals.net ForFinds.com
    I still think it is BEST to install PANASONIC IC's.....I use them
    for STK392-040 in whatever brand I am repairing........You could
    rebuild your original board with..Part # C5AA00000107......about
    $30.00 each....if it works you could send the new circuit board
    back for defective refund...........T.
    Genius:
  • 1,153 Answers
When amps go bad most of the time they cause fuses to open in that area. They also will need return resistors replaced. Unless you have done all of this then, you should not replace with new ones, it will only damage them also. You may need schematic to find the fuses and resistors.
Posted on Dec 23, 2007
  • Lashawn Robinson Dec 26, 2007
    You will definately need the old codes before erasing what is on your EEprom in set. I don't have a list of this but if you get it I can assist.
    Master:
    Sergeant:
  • 482 Answers
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Freezer frosts up, frzer & frig loose temp. Need to defrost freq
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 31, 2010 | Refrigerators
How 2 fix JVC AV-65WP74
Sounds like a vertical IC failure. I would try replaceing the IC that may repair the issue.
Dec 31, 2009 | JVC AV-65WP74 Rear Projection Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Sound works no picture
t.v sounds comes on picture not working can watch pip . sometimes when you turn the t.v the timer light in front flashes can u help
Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai CF2791 27" TV
I have a troubleshooting procedure file who is in PDF format , i don't know how i can send that to you.
Any way if you are a technician , send me a small message to my email so i will send you all the information attached to the message which i will send back.
Thks
Sep 24, 2008 | Akai Televison & Video
Power supply
I found THIS weblink having info for Akai LCD TV parts. Please check it as it might help you.
Aug 06, 2008 | Akai LCT3201AD 32 in. LCD Television
Convengence problem?
the stk ic . the big amp chip has cold solder joints . resolder the ic
Nov 30, 2007 | Mitsubishi WS-55857 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
