Question about Bosch Saws
Change blade 1587 Bosch avs
Jig saw 1587 AVS Bosch after following directions the blade will not turn to a position to operate
  • 2,176 Answers
Are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
I have a 1587 AVS, changing the blade, I turn the blade into the proper cutting position and turn the nob but the blade will not tighten.
You have to pull up on the knob while you tighten it, without pulling it off the saw. A bit tricky.
Also helps if you gently pull out on the blade a bit as you tighten. See this rant of mine on the same topic, which includes a link to the online manual.
Best of luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2011 | Saws
I have a Bosch 1587 avs. I am trying to change the blade. I have followed the instructions as per Manual. In the last part I am supposed to hear a click to lock the blade in to position while rotating the...
First unplug tool and lift up on the knob and loosen the spindle lock, insert blade and push up slightly while doing so and twist to align blade with the roller, while lifting up tighten the knob until you hear it click and the blade should be tight and stay in place. Let me know if you need more assistance.
Apr 04, 2011 | Bosch Saws
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
I want to remove the blade (Jig Saw 1587 AVS
there should be a botton or thumb press undernith up frount unplug and depress and blade will come out
Apr 09, 2010 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Bosch 1587 AVS blade install problem
I bought this saw and then wasted some time looking for "SDS" blades (which my manual called for) until I discovered that a T-shank blade was what was required. As far as the blade change goes, I had to practice changing the blade a few times before I figured out an easy way to do it. It's not so much that the top knob has to be pulled up hard, but it must be raised approximatley 10mm or 3/8". This knob will then either loosen (counterclockwise rotation) or tighten (clockwise rotation) the blade retaining mechanism. A good indication for me when the know was high enough was when I could see numbers exposed on the inner portion of the top knob (the neck) and could also see (when I looked under the top knob) that the top knob was now engaging the "teeth" on the small white phenolic gear. It is this gear that actually loosens or tightens the blade. The blade will loosen once the knob is turned counterclockwise (3 times), but the backside (smooth side) of the blade must be pulled away from the guide wheel as it is rotated 90 degrees. To install a blade, you you simply reverse this process. An audible click will be heard when tightening, but I would certainly always double-check to make sure the blade is tight, before operation. I almost ran the jigsaw with a loose blade the first time I put a blade in the saw. I hope this helps...
Oct 15, 2009 | Bosch Saws
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
Instruction manual for Bosch Jig Saw 1587AVS
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Mar 31, 2009 | Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Saws Logo
526 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
