Question about Magic Chef CAV2000AWW Top Load Washer
I am looking for the manual i have 5broken springs in the bottom and not sure were they hook
    President:
  • 1,734 Answers
I found your (service) manual here:
http://docfiles.info/appliance.php?cmd=document&device_typ_id=1&brand_id=21&q=cav2000
Posted on Oct 06, 2009
    Problem Solver:
  • 18 Answers
Go to google,type your product&number u should get the manual than print it
Where does the bottom of the spring hook into on my 86 D21 Z24 Its right behind the FIC alignment mark piece.
it should fit right into the tremelo if i understand the question correctly. but it should have more than one spring . and would tell you just by looking atb it. good luck
Aug 04, 2014 | Fender Tremolo Tension Springs Black
How to replace the speed control plate
Take the back cover off, remove the wires. Unclip the spring from the bottom of the plate, don't let it fly back inside the housing. Unlock the 2 screws at the top and undo them. Fit the new plate, each screw 8 turns in to start with. Hook up the spring, put on the wires where they came from. Start machine on speed one, and adjust the top screws evenly to give the planetary 13 to 15 revolutions in 15 seconds. Lock the screws up with the lock nuts. The screw at the bottom is then adjusted so that it gives a slight speed increase when you enter speed 2 from speed 1.
Jul 29, 2014 | KitchenAid K5SS Mixer Speed Control Plate...
Missing mount springs
There should be 3 or 4 springs on a washer depending on the brand. Its mainly for extract but it does hold tub in place.
Apr 08, 2014 | General Electric WBSR3140GWW Top Load...
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Can't figure out where to hook the idler spring onto the mower deck on my DYT 4000
look at the picture on the bottom of the foot rest there is a picture there
May 18, 2012 | Garden
Which way does the top spring go in? (theres a fix hook like curve at one end a different hook at the other end of the spring)
if you are referring to the suspension coil spring then if you look at the spring the tighter coils go to the top and the more spaced out coils go to the bottom.also the tighter curve usually goes to the top.
Jun 29, 2011 | 2000 Dodge Stratus
Where does spring from pully go
The spring will attach to the frame of the dryer.
Hook your spring to the pulley and then try to attach it to the frame of the machine moving it to different locations on the frame, just remember it will have to stretch a little to attach so keep that in mind as you mentally try to hook it to the frame.
Look very carefully at the bottom of the dryer frame, it will show a very slight wear mark, and that will show at which point to attach the other end of the spring.
This is a FREE answer, Please Rate Me
You can also purchase a owners manual for the dryer to assist you in this project...and future projects with this dryer
Sep 26, 2010 | Amana Dryers
The spring popped off my mayday dishwasher door. I can't figure out where it goes to put it back.
look at the other spring ..their is 2 springs ..they hook to the bottom rail of the D/W let me know an good luck P/S remove the bottom cover plate to see the springs they are located on the left and right side /joe/
Aug 29, 2010 | Maytag Dishwashers
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
Magic Chef CAV2000AWW Top Load Washer Logo
100 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
shaun taylor
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
