Question about Neff Washing Machines
I have a NEFF V4380X0GB washing machine. Can you tell me what the ECO & SHORT buttons do individually and when pressed together please.
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 228 Answers
SOURCE: neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Posted on Aug 05, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: NEFF WASHING MACHINE
Check voltage in the outlet, it may be too low.
Posted on Jan 07, 2010
  • 88 Answers
SOURCE: Dishwasher fdb4315lfc stuck with eco wash led and a pump running
Sounds like the Anti-flood switch has been triggered - possibly due to overfilling. Check seal of water level pipe at each end.
Posted on Feb 28, 2010
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
Neff v4380x0gb not drying
The heating element is faulty
Oct 14, 2012 | Washing Machines
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD
Jun 26, 2011 | Washing Machines
The child/safety lock won't release at the end of a wash cycle so I'm unable to take my clothes out of the machine. I've tried a different cycle, turning the machine off, and switching the...
Thank you for contacting fixya.com.
You did not mention the type and the brand of your washing machine. However given bellow are some options you can try.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing machine try holding down the temperature and eco/rapid options together to turn off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the suggestion
Jun 17, 2011 | Washing Machines
Machine not empting the water after wash
The water not emptying after wash could be due to several reasons.
The filter at base is clogged or the drain hose is clogged or if you have insinkerator (garbage disposal) under sink that may be full.
It would help if you can confirm if the drain pump motor is operating at the end of the wash cycle.
Also try the reset function. Have master switch in ON position. (left most button on door top).
Then press the A & C buttons (1st and 3rd buttons from left on the cluster of 4 button on the right) together for 3-4 secs.
Dec 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Why does my lg washing machine dissplay CL on it and i cant turn power on
Hi
CL means you have activated the child lock or it may have activated after some buttons were pressed. Try holding down the temperature and eco/rapid options together to turn off child lock. If this doesn't work then unplug the washer for 5minutes and try again. Hope this helps... Please post back if you need more information.
Dec 11, 2010 | Washing Machines
My washing machine gives a CL error code
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | LG WD-1280FHD Front Load Washer
Hi there, my LG wd-80481tp is displaying CL, none of the buttons are working and my manual is in greek, can you advise on the problem please? thanks
Hi
Thanks
Rylee
Oct 26, 2010 | LG WD-1280FHD Front Load Washer
CL error code. what does it mean?
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Washing Machines
No problem really but our charity has been given a fisher paykel eco washing machine with no instructions. Great really but what we want is a simple operation sheet that we can attach near the machine so...
Pretty much just turn it on & it will do most everything automatically.It will auto sense the water level for you & pretty much do everything itself based on the weight of the clothes..Press (Power Button)..Then press (Start button)..& Bobs your aunties live in lover! Sorry humour.
Jun 01, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
54 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
