Question about Kyocera FS-2000D Laser Printer
Kyocera printing very slow from various applications running Win XP on a POS system.
  • 622 Answers
First in the driver under advanced settings... make the driver spool the print jobs...
and if that doesn't work try pcl or kpdl drivers...
Posted on Dec 24, 2009
Kyocera slow printing
First you have to determine if the problem is mechanical of electrical. Are the letter bunching up. If so the print shaft may need oil. Is the data from the computer being held up some way. Bad interface maybe? Are you using the proper print driver. The wrong or damaged driver can cause print problems of various types. Check for computer viruses you would be shocked at what a virus can do to your printing. Start with those suggestions. Then come back.
May 11, 2014 | Kyocera Office Equipment & Supplies
My dell inspiron mini 10 notebook using window 7 pro..why it always hang when i opened many application..
The Dell mini computer runs on a Intel Atom processor and has just 1GB of RAM on it.. So the computer is designed only for internet surfing and launching small applications.. Thats the reason it is called as a netbook.. It comes with win starter edition... It is not highly recommended running a win 7 pro on this machine.. It can be really slow on this Operating system... Thats the reason your computer is slow.. Try to run inbuilt cleaning like disk clean up to see if there is any iimprovements in speed.. Else switch the Operating system to win XP or Win 7 Starter
Nov 02, 2010 | Dell Inspiron Mini 10 Notebook
Print jobs don't get into a queue when print server is offline
you must repair sharing to your all network,if not work you must check cable Lan connection try this.good luck
Apr 24, 2010 | Microsoft Windows XP Home Edition
Old program won't run on new computer win XP but runs on others
> ran slow
Probably, having more RAM would make VMWARE run faster.
> except Sound Laundry 2.5
Check the manufacturer's web-site -- surely, they have a version which *DOES* work as a "native" application under Windows XP and Windows VIsta and Windows 7, i.e., no need for "compatibility settings".
Nov 05, 2009 | HP Pavilion A6400f Desktop PC, Refurbished
What are the basic applications that runs on Windows XP O/S?
well every application and software is built on on a platform that is compatiable with some certain operating system . u should have encounter some applications that run well in xp and vitsa but are not compatiable with win 9X and others . win xp also introduce a option of compatibility for applications . just right click a .exe file and go to properties there u will find some options . suppose if u have some application or software which were runing fine in win 9x and 2000 but seem not to work in win xp u can set option from compatibility than how the system should run the application and in what platform . if u choose win9x/2000 option the o/s will trick the software that actually its runing on win98/2000 . but it works in some cases . i hope u understand thankx and take care of urself
Jun 11, 2009 | Microsoft Windows XP Professional for PC
Tm t88iv print slow
This is definitly a driver problem. Change the driver to one that is compatible with Win XP.
Jun 03, 2009 | Epson TM-T88III Printer
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Win Vista and Win XP Probs?
which applications are not compatible? Do you try to run them in compatibility mode set at windows XP?
You may install VMWare Server to run a virtual machine XP from Vista without dual boot, allowing running XP and Vista at the same time, its easy to install/configure, need a good computer with 2Gb ram min.
Jul 04, 2008 | Microsoft Windows XP Professional With...
PC slow while printing
when printers are being used it requires a lot of memory especially for larger files.
my first suggestion is to get more memory, however to validate that it is the problem press ctrl alt delete and go to the system monitor to see the ram usage during the printing, if its maxed out then you know its 100% needs more ram.
in the short term you can increase manually the virtual memory of xp so it uses the harddrive as temporary memory to make printing faster
good luck
smeags.
Jan 03, 2008 | Microsoft Windows 98 for PC
Kyocera FS-2000D Laser Printer Logo
825 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
