Question about Electrical Supplies
Replaced a light switch in one part of the bathroom, now another light switch and fan switch does not work in same room.
  • 313 Answers
  1. If you JUST replaced the light switch, take off the cover and check the connections to the switch. Check that all the neutrals have a good connection, that is usual the case.
  2. If the light switch you just replaced doesn't work check the breaker.
  3. IF you replace a fixtures (light, Ect) check the connection on that as well
  4. Have an electrician come out and look for a short.
If you can not find the solution, please have some one check it out. You don't want anything starting a fire.
I hope this helps, with out actually being there, looking at it, it leaves a lot of variables to be more accurate.
Thank you for the chance to help.
Randy
FixYa Support Team
Posted on Oct 06, 2009
Grounded
This is my first thought. Do you have GFI in you house.
I lost power on my front porch one time, found out it was the GFI in my bathroom tripped. Reset it and everything was good. Nothing wrong with the GFI it was my kids playing with it.
Jan 21, 2018 | Home
Should the bathroom fan light turn clockwise or counterclockwise
Which direction are the fan blade setup to exhaust the air out of the room? That is the direction it would spin, as this is not designed to pull air into the room.
Mar 17, 2013 | Broan-NuTone N-8663RP Combination Light...
Three lights and the bathroom fan stoped working on my 79 rockwood
you take the bad light bulbs up . then buy the same model lights .install them on the switch.
ceiling light
May 23, 2012 | Dryers
I just replaced the 2 light switches in bathroom they still dont work
you need the critic checked,a om meeter is need
Apr 21, 2012 | Home
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Electrical Supplies Logo
91 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
