How can I get any ads to appear in the area I am targeting
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
What are you talking about when you say area --- are you talking about geographic targeting or category targeting?
Geographic is fairly straight forward, Category is much more copmplex.
Geographic: What you need to do is get the end users IP address.. So I connect to your server - you server has my IP - which if you do a DNS lookup will tell you where I am located
From this information you can make sure American's receive America Adverts, French receive French etc...
The best source of information on this including the data you require to match an IP to a location is available from Maxmind.
Category Targeting - that is showing Car adverts to people who are interested in cars is far more complex. However, what you require is a tracking cookie (check on google) which will teel you the sites and searches people do after they have visited your site.
There are a number of companies that supply services to manage such work for you... however, this type of targeting is not only frowned upon but in some locations regarded as illegal and an invasion of privacy unless the user specifically requested the tracking cookie to be installed.
If this has helped you the please vote
Posted on Oct 09, 2009
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
Is it true the facebook messenger app can be used to spy on you
Not to be the bearer of bad news, but any information you put on the web can be linked back to you. Since you have a username that is unique to you, it could be traced.
I would suggest having a look at the FB privacy statement and terms and conditions. The have targeted ad-based marketing that stores "cookies" on your computer to track your interests.
If tracking you means spying on you then the answer to your question is yes. How not to be tracked? Don't use the service, or limit confidential information.
Dec 28, 2014 | Facebook Apps
Precor treadmill err26
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
Some one have used my email address to send advertisement to me, how can this happen and how to fixe this.
First, change the password on your email address. something "strong"...use capital and lowercase letters and numbers (XxX123ZzZ)
It sounds like someone signed up for a website/service that sends advertisements to your email address. The advertisements probably have the name of the site sending them. You might be able to go to that site and discontinue your account there.
You can also block future advertisements using filters (assuming all the advertisements have something in common...who sent it, subject, etc)
In the upper-right corner of your Yahoo! Mail page, click the Options link, then select Mail Options from the menu.
On the left side of the page, click the Filters link.
On the top of the Filters page, click the Add Filter button.
A page appears where you can define the rule and the destination for the new filter.
Type a unique name for the new filter in the Filter Name box, such as "advertisements"
Define one or more rules for the filter.
  • From header-Who sent the message.
  • To/CC header-Who the message is addressed to.
  • Subject-The subject text.
  • Body-The message or body text.
From the Move to Folder pull-down list, choose the destination folder where you want the message to go (probably SPAM)
  • Contains-the area must contain the target text. For example, the target text "Chris" would match all the following: "School project on Christopher Columbus," "I forgot to call Chris," "chris9441@yahoo.com."
  • Does not contain-the area must not contain the target text. (This is a negative condition.) For example, the target text "Chris" would match any area that does not contain "Chris."
  • Begins with-the area must contain the target text at the beginning. For example, the target string "Chris" would match "chris9441@yahoo.com," but not "School project on Christopher Columbus" or "I forgot to call Chris."
  • Ends with-the area must contain the target text at the end. For example, the target string "Chris" would match "I forgot to call Chris," but not "chris9441@yahoo.com" or "School project on Christopher Columbus."
Click the Save Changes button to save the filter.
In the worst case you can just get a new email address and tell your contacts about it.
Feb 08, 2011 | Yahoo Mail
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
