Question about Kyocera MARBL K127 Cellular Phone
Phone is OFF what happened to my phone? It just turned off and the screen says "phone is OFF"   What does that mean?
Touch screen not working
Well, if you touch screen is giving you trouble is because something happened to your phone, meaning it felt or hit it onto something. They don't go wrong because they feel like it. Something must to happen in order for it to react. If you want me to give a solution please let me know what happened to the phone.
Mar 29, 2014 | Samsung GALAXY S4
Screen will not turn on my htc after charging
first put in your simcard POWER ON your phone ...let the screen go off ...see if you are able to receive calls ..if yes then you need to change the flex cable or the LCD..if you are unable to receive calls then it means you need to put in a new software y upgrading
if your NOKIA PHONE SAYS INVALID SIM or PHONE RESTRICTED ..IT MEANS YOUR PHONE IS NETWORK LOCKED.IT WILL ONLY WORK WITH A PARTICULAR SIMCARD ONLY PROVIDED TO YU BY UR SERVICE PROVIDER......YOU NEED TO UNLOCK IT IN ORDER TO USE THAT PHONE WITH ANY OTHER PROVIDERS SIMCARD...WE CAN UNLOCK ALL NOKIA IPHONES SONYERICSSON MOTOROLA HTC BLACKBERRIES AND MANY MORE ..CONTACT US ON gsmspeedAThotmailDOTcom
Sep 12, 2012 | HTC Desire Cell Phone
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
Blackberry 9780 white screen
Software/Virus:
Flex problem
Conclusion
Good luck.
Jan 12, 2012 | Cell Phones
Phone working but screen is black
Software/Virus:
Flex problem
Conclusion
Good luck.
Jan 10, 2012 | HTC HD7 Cell Phone
My c168 gives back light only
Software/Virus:
Flex problem
Conclusion
Regards.
Jan 04, 2012 | Motorola Mobility C168 Cellular Phone
Vertical lines on screen
same thing happened to me.so i phoned up my insurance to take a look at it and they said it had something to do with the pixels on your television
Dec 15, 2011 | Televison & Video
I have an HTC hd2 when I turn my phone on the slide thing on the screen won't slide, so the phone won't unlock. Sometimes it will work but not very often.
the problem is that your Touch Screen Digitizer is dying this happens to alot of HD2's from a year to about 2 and half years is when the issue starts to come to light. to fix it, it need to be replaced i suggest a profesional which can cost about 140 bucks or you can do it your self for 80$http://www.youtube.com/watch?v=eaaY0Dva8KQ
Aug 31, 2011 | HTC HD2 Smartphone
Blackberry storm screen freeze
remove the battery and leave it out for 2 minutes.
replace the battery in the phone and let it boot.
see if it works. If it doesn't work return it to where you bought it for a new one. the screen is probably defective.
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Screen keeps going white
If it turns out to be not the display chips but the screen there is an Blackberry Repair Guide that shows how to open a Blackberry and replace the screen. Once it is open it's as easy as taking the broken screen off the front assembly and installing a new one, the parts are available on ebay. If it's the logic board that can be replaced as well. Blackberry Repair
May 21, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Kyocera MARBL K127 Cellular Phone Logo
29 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
