Which colour lead is live and which neutral - I have one connection with a black and a red wire coming off, and the other with a green wire to the switch. (replacing mains lead as it was damaged.
how do i take the coffee grinder apart, to clean it? it doesn't run smoothly anymore. i think i need...
(More)
how do i take the coffee grinder apart, to clean it? it doesn't run smoothly anymore. i think i need to take the metal bowl-like piece out of the grinder?
We have a breville BCG 450 grinder. It does not grind fine enough. Even on the Turkish setting it is...
(More)
We have a breville BCG 450 grinder. It does not grind fine enough. Even on the Turkish setting it is still granular. What is the problem? Has anyone else had the problem?
I have a Capresso Infinity Burr Grinder 560. Took it apart to clean, and reinserted the upper burr...
(More)
I have a Capresso Infinity Burr Grinder 560. Took it apart to clean, and reinserted the upper burr with soft collar. Then tried to reinsert the bean container, but it would not go in. Tried to remove the upper burr to see if it was in wrong but it will not budge, (It is NOT upside down!). Can you give me any clue as to how to remove the upper burr?
