Question about Air Tools & Compressors
OPV on third stage keeps blowing? We have rebuilt 3rd and 4th stage valves, and changed unloader diaphrams. Ideas?
  • 54 Answers
Safety valve may be weak. Try replacing it. If you don't have a pressure gauge, try installing one to verify actual pressure.
If your machine has more than 4 stages, the higher stage(s) could still be your problem. If a 5th stage isn't performing, the lower stages have to work harder, for example.
Posted on Oct 22, 2009
Trans revs up and slips between 3rd and 4th gear
Could be many things. Depends on transmission. Band, servo, seals, valve body. Take it back if rebuilt at a garage. Most have 1 year, 12000 mile warranties
Dec 27, 2015 | Cars & Trucks
Can't get 1988 f150 4 speed to shift into 3rd and 4th gear
If fluid levels are correct, it sounds like the transmission needs to be rebuilt.
Jul 29, 2014 | Transmission & Drivetrain for Ford Transit...
Not changing pass third gear had transmission rebuilt twice in past year, fluid is fine Rpms race to five
Hi :) Sounds like the clutch pack if the machanic didn't setup the T.V. Cable The right way the hydraulic pressure wouldn't be properly set and as you are driving the clutches would be slipping everytime they change gears and since you use 3rd and 4th the most they go first.
May 06, 2011 | 2000 GMC Yukon
1997 Ford Taurus, Won't Shift Past 3rd Gear
Ford is very common for tranny problems. Most likely your tranny will have to be rebuilt. As a mechanic myself, I would suggest taking to tranny specialist to see if i needs to be rebuilt, or if the electrical unit is faulty. It will have to be tested with voltmeter/ohmmeter/multi-tester
Sep 16, 2009 | 1997 Ford Taurus
Head stud torque
cyl head torqes.1st stage 29 nm. 2 nd stage 57-67 nm. 3rd stage slacken off 360 cegrees, 4th stage 29 nm. 5th stage 64-74 nm. intake and exhaust valve clearance .38 mm hot setting. hope it goes ok.
Aug 14, 2009 | 1987 Nissan King Cab
Hang up in third gear loss of power
Hi All
I have a s40 1.9d / 2000 plate,
In the last month or so the car loses revs when changing up to 3rd and 4th gear, I can only get 50 mph max in 3rd gear 80mp in 4th.
The car has just clocked 185,000 miles
Its a great car but a pai at the moment, I've had a service including fuel fillter change added fuel cleaners to the deilsel all to no avail
Any suggestions
Jul 06, 2009 | 2000 Volvo S40
With compressor running the relief line blows off
check that the non return valve is not stuck closed
hope this helps ian
Feb 24, 2009 | Campbell Hausfeld Single Stage Air...
Automatic Transmission Rough Shifting
From the sounds of it you need to have your transmission rebuilt, there is no quick fix for a fault in one gear. As far as the tapping noise goes quite often a oil change is all that is required to cure it.
Feb 08, 2009 | 1999 Volvo S80
''friend '' rebuilt l460e now no 3rd or 4th,
Did it not work right after the rebuild or did it work for a while then quit?
Jan 13, 2009 | 1995 Chevrolet K1500
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
