Question about Turbo Air MSR-49G-2 Commercial Refrigerator
I have had my cooler for about 1 month. I have noticed that it goes into defrost mode at least once a day. Is this normal? Thanks for your help.
  • 909 Answers
If its cooling correctly, it is correct. Defrost time is what the designer sets it to.
Posted on Oct 06, 2009
Testimonial: "Thanks."
    President:
  • 1,304 Answers
Yes it sounds like your defrost timer is set two 8 hous, possibly 12 but since it sounds like your hearing it twice during the day id bet 8
any way if its cycling and not leaking, and maintaining temp its normal as they say
next time take a listen if you hear it go into defrost, it should come back out in 20 +- 5
  • milten1
    milten1 Oct 06, 2009
    yes it sounds like your defrost timer is set two 8 hous, possibly 12 but since it sounds like your hearing it twice during the day id bet 8
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Freezer defrost
If the unit is less than 10 years old going into defrost at least 3 times a day is totally normal and not harming anything.
Mar 01, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
We have Ice biuld up and have defrosted twice
On R22 coolers the cycle of on off is the way the defrost takes place when you begin to notice on the evaporator coils the refrigerator is showing signs of loss of R22 Freon. Now some do have defrost elements built into the evaporator coil inside the cooler section but because it is a cooler I don?t think so. The question is has the refrigerator begun to continue running and the temperature climbing slowly. Have you noticed that the cooler is hard to maintain 37 to 42 degrees? Let me know more so can help you better, Thanks Sea Breeze. You are welcome to visit mu website and enter the model number into the model search feature a see just what is listed as replaceable part. Click on link or copy and paste into your browser web address bar the address Email> appliancepartsse@yahoo.com http://servicepartstec.blogspot.com/ <Site Check th drain pan below the cooler does it have condesate inside the tray?
Jun 10, 2009 | Refrigerators
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
Frost build up in freezer and warm temp in a GE Profile TFX22PRXB
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal. Your refrigerator most likely has a defrost timer located on bottom behind grate, or inside behind control panel. Could you find the correct model number so I can help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 24, 2009 | GE Refrigerators
Freezer coils get covered in ice about once a month
If the fan is running, replace the defrost thermostat!! Make sure the heater is working... see blog on testing the timer and heater!!
Good Luck!!
Aug 17, 2008 | Frigidaire FRT18G5A Top Freezer...
Whirlpool not cooling properly
I would expect the defrost timer to stay in defrost 21 minutes. IT seems your timer is normal.
If turning the ref section temp colder made compressor come on, it could be that the thermostat is worn a little and just needs to stay on a little cooler setting. Check the freezer temp dial and It should be at just slightly more than 1/2 of available setting. If there is A B C you would want to be a little cooler than B about B and 1/4.
I hope this helps K S
Nov 22, 2007 | Refrigerators
Heating element in a refrigerator?
The orange glow you see is your defrost heater. Your refrigerator goes into the automatic defrost mode three times a day. This keeps the unit frost-free.
Oct 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all Turbo Air MSR-49G-2 Commercial Refrigerator Questions
Turbo Air MSR-49G-2 Commercial Refrigerator Logo
89 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
