Question about Kenmore 72202 / 72204 / 72209 Top Freezer Refrigerator
Moisture is accumulating on top of the freezer due to a small crack. is it safe?
    President:
  • 1,304 Answers
Its safe but will be a pain
if you have a small crack in the liner
you can buy white tin tape and get a good seal again
but if you willing to deal with it
and wipe it down alot
you will be fine
Posted on Oct 06, 2009
Testimonial: "Cheers mate, thanks for your rapid and expert advise."
Excessive moisture accumulation in fridge
condensation due to clogged evaporator drain plug or bad door seals
Mar 15, 2015 | Refrigerators
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Water leaking from top of fridge
If the case is cracked or there is a leaking door seal this will allow moist air from outside the unit to come in and release its moisture. Cracks are easy to see. You can also inspect the seals fairly easily.
IF YOU TRY ANY OF THIS PLEASE UNPLUG YOUR UNIT AND TURN THE WATER SUPPLY OFF FIRST. thank you.
Freezers/fridges remove moisture from the air inside them while they work. At least in my unit the fridge and freezer compartments are connected by a couple little trap doors. One near the top works automatically. I assume it regulates the temp of the fridge part by using freezer air. The other is vented into the meat drawer at the bottom.
Moisture flows to the coldest part of the inside, much like humid air settles droplets on the outside of a cold glass in the summer. The coldest part is the coil assembly which would be behind a panel at the back of most freezers. Below this assembly and hopefully not covered by a panel is a drain hole. It needs to be clear for things to work properly. See if you can find it in the back bottom of the freezer.
If there is ice plugging it you need to clear it. Don't pick at it because the inside of a freezer doesn't like scratches and scrapes. Those create opportunities for rust if the unit lasts long enough. Put a few towels in the bottom of the freezer to catch overflow. Then pour the hottest tap water you can get slowly over the ice. Once it is clear the drain lets the water go into a pan underneath the unit and eventually evaporates. You will hear it when it clears.
Under normal operations this drain collects the water that freezes all over the cooling coils in the very back of the freezer. It is normally very little water. If it is blocked by ice this can point to a slightly bigger problem. You may want to see if you can remove the back panel of the freezer and check the coils for ice. This can a)take a while and b)have you removing a lot of assemblies just to get to one panel screw. So be prepared and don't start it when you have a freezer full of food. If you attempt it and find white fluffy looking ice all over your coils you will need to look below this stuff for an assembly that houses a heater. Mine looked like a long thin tube bulb, much like a halogen lamp. It's called the heater element and replacing it may just fix your problem. I got mine for about $50.
You might also want to make sure your fan and radiator assembly are clean. Inspect the air venting grill on the back. If that is gunked up or you can see that the radiator inside is gunked up, you should carefully remove the panel and vacuum as much as you can. This was a major problem for me because at one time because of indoor pets. If checked regularly it doesn't become an issue.
Anyhow, this is a lot of info, but I had to learn all this the hard way. Hopefully it will save you and others a headache.
Dec 06, 2011 | Kenmore Top Freezer Refrigerator
5 yr old microwave has worked perfectly - until now. Put small amount of food on a safe plate in for 45 seconds. Plate suddenly cracked, was extremely hot - and food wasn't even warmed.
The plate wasn't microwave safe or has a crack in it that had moisture in it to cause it to split.
A new pyrex type glass plate will get it going again.
Mar 08, 2011 | Microwave Ovens
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Mold in fire safes is common :(
Most likely, Due to possible dampness in your home collecting in the air tight small container would be the cause of mold. Or it could be humid in the safe that would result to mold because mold would grow in the small dark area. All you really have to do is clean the safe with lysol or some type of antibacteral cleaner..wouldent suggest water alone for obvous reason of it being the possible problem to start with.
Hope this helped.
Aug 16, 2009 | Sentry Fireproof Safe
Excessive moisture accumulation in the refrigerator
clogged freezer drain or faulty door gasket, most likely the first one. remove back panel of freezer and thaw out drain completely after removing ice.
Jul 01, 2009 | Whirlpool ET4WSKXS Top Freezer...
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Motor runs, some ice at top level, but temp is at 50-60 degrees.
Defrost the freezer. Door being ajar allows moisture to build on the freezer coil and stops air circulation. In frost free units this condition should clear itself after about 8-12 hours max. Locating and advancing the timer by rotating the clutch head screw clockwise slowly until you hear one click. This will start the automatic defrost manually.
May 19, 2008 | Sanyo SR-4912M
Kenmore 72202 / 72204 / 72209 Top Freezer Refrigerator Logo
87 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
