Question about Dell Inspiron 1420 Notebook
Overheating I have a Dell Inspiron 1420 that seems to be overheating. It gets hot enough to burn your skin, but only on the left side. I checked the fan and vent for dust and they are both clean. The fan is working. I am not sure what to do, but I have to have my computer for my online classes. Please Help! Thanks!
  • kristinaward Oct 06, 2009
    I have it on a table surface and prop up the front to give it proper ventilation. Even if I have only one program going at a time it is still hot. I have downloaded a cpu temperature monitor from www.cputhermometer.com and the thermometer maxes out at 130, and it shows my temperature above that. Now I am very scared that I am going to fry my computer!
  • 700 Answers
Ok fan is working and vent holes are clean. well you must have to purchase a laptop cooler. Buy a design well suited for your bottom part.
Or purchase a fan design cooler which will coincide where the most heat is generated. Or one big fan that will cool down the heated part.
This will also added to heat generation. But much better than no fan at all. Also it will deplete much faster your laptop when not plug on AC socket. Try to select lower amperes sink but have better cooling effeciency
Hope this helps.
Posted on Oct 06, 2009
  • 3,940 Answers
There is a difference between getting hot and overheating. Most current model portable systems will have portions of the bottom of the chassis that will get hot enough to burn skin due to the location of the processor and the heat sink.
If the system is overheating you will have some if not all the following symptoms:
  1. System is crashing at boot of within a few minutes of operation.
  2. System is slow
  3. System is giving blue screen errors
  4. Fans either run constantly at high speed or do not fun at all.
  5. System restarts unexpectedly.
If your system is overheating, here is the Dell Troubleshooting Wizard for that system:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=19&l=en&s=dhs&treeid=5B6BB978941A56A1E040AE0AB7E17881&journalid=75416C6BA391B4BEE040AE0AB8E13529&Query=bGFwdG9w&SystemID=INS_PNT_PM_1420&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
But: If the only issue a an isolated hot spot on the bottom of the system (No Crashes, reboots, blue Screens, Errors or fan racing all the time) then my answer is the system is operating as designed. Due to ever increasing processor speeds & lighter and thinner designs hot spots on bottom of the system are not unusual. Manufacturers will tell you to use the system on a hard FLAT surface that allows maximum airflow. Use on a lap, carpet, bed, blanket or other soft surface that can impede airflow will result in the system running hotter, and in some cases overheating. This is why the Lapdesk market has become very popular.
http://www.google.com/products?rlz=1C1GGLS_enUS345US346&sourceid=chrome&q=lapdesk&um=1&ie=UTF-8&ei=a1TLSuGlIYKltgfKna3kAQ&sa=X&oi=product_result_group&ct=title&resnum=4
  • IQUIT Oct 06, 2009
    Again, the big question is: Aside from the heat, is the system running normally? If the answer is NO, then you may have a hardware issue that needs to be addressed. You can take canned compressed air, and use it to blow out the air intake and exhaust vents (The heat exchanger can get clogged with dust and debris) If that has no effect, then if under warranty, contact tech support to get a new heatsink and fan installed (The heatsink has vacuum sealed copper tubes, sometimes they leak)
    If not under warranty, then take to a local shop, and see if they can add some ARCTIC SILVER heat compound on the heatsink to better conduct heat and check the fan operation.
    The 130 degree temp you mentioned, if that farenheit or Celcius? 130 F is nothing for a processer, and 130C a tad bit hot.
  • 34 Answers
Are you leaving it sitting on a fabric surface i.e- pillows. blankets... beds carpet?
also not enough ram, too much going on at one time can do that. Make sure your fan is working properly and maybe download a cpu temperature monitor. google it u should find something
What kind of fan works with kn548 to cool cpu???
Look for the model on the fan and search for that model on ebay. In fact you probably could just search on ebay for Dell Inspiron 1420 CPU Fan and get it.
http://www.ebay.com
May 06, 2012 | Dell Inspiron 1420 Motherboard - KN548
My dell inspiron 1525 wont open. Im sure that the power cable is working. Before, everytime I use it, it is too hot as if the fan isnt working at all. I dont know if some capacitors are burned already.
This laptop is fairly easy to check for overheating causes.
Remove the large cover from the back of the laptop to reveal the CPU and heatsink fan. Clean the area around the fan and heatsink. Power the laptop on and see if the fan moves ( also see that the 3 pin connector that connects the fan to the motherboard is plugged in).
Check for blown capacitors, burning around the components and signs of overheating on the board area that you can see. You could try replacing the CPU chip in case it has burned out, however, I rather suspect that the overheating has damaged another component on the motherboard and a replacement motherboard is required
Jan 29, 2011 | Dell Inspiron 1525 Laptop
The battery indicator of my Inspiron 1420 flashes amber and blue indicating that the battery is too hot to charge. Obviously the cooling fan is stuck. can anyone help me where I can buy a replacement...
It is not obvious that the cooling fan is stuck. If the battery flashes amber, amber,amber, amber, blue then repeats, the battery has an internal failure and needs to be replaced.
The cooling fan only cools the CPU and the graphics, not the battery.
Jul 18, 2010 | Dell Inspiron 1420 Laptop
Left internal spkr not working
Try connecting an external set of speakers or headphones, see if you get both channels, if you do, then the speaker assy is bad and needs replacement.
If you only get audio on 1 channel externally, then check all the sound settings in Control Panel (make sure correct speakers are selected and the playback settings are all correct.)
Jun 29, 2009 | Dell Inspiron 1420 Laptop
Overheating dell inspiron 1420
Hey there, I have two possible solutions for ya. First, I know it is only 3 months old but I would check to see if the heat sink is clean. They are located in the back left corner. The part that should be cleaned looks sort of like fins on an air conditioner. If you shine a light through the slots you can see the fins. The dirt builds up on the inside of these fins and cause overheating. The easiest way to clean is with canned air but if you are to the point of overheating you may need to disassemble the laptop. Second suggestion is to download and install speedfan. Open it up, click on configure then options, there is a box to check for DELL support, click that. This will tell you your temps as well as if any sensors are missing or not reporting. Let me know what you find out.
seth
click on SpeedFan 4.38. in second paragraph (download)
http://www.almico.com/sfdownload.php
Jun 25, 2009 | Dell Inspiron 1420 Laptop
Over heating of my DELL INSPIRON 1420
check processor fan and use extra portable laptop fan.
Jun 01, 2009 | Dell Inspiron 1420 Laptop
The fan could be faulty (ie stopped spinning) or the heatsing vents are clogged with dust.
Remove the fan and check/clean the vents/fan. If the fan is faulty replace it.
Mar 13, 2009 | Dell Inspiron 1420 Laptop
Inspiron 5150 fan continously running
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Jan 20, 2009 | Dell Inspiron 5150 Notebook
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
