Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
This pump is at least 18 to 20 years old. (Flotec) Type B, Motor Model C48K2EC15 HP 1 RPM 3450. It is leaking in several places, mostly at the top and the water pressure is not very strong. Is it a gasket? (water seal?) Now what. Do I follow the direction on replacing a gasket?
  • 120 Answers
Man, its time to move on and replace it with a new one. Way too much trouble to find parts for an old unit .
Posted on Oct 06, 2009
Leak from motor
We need the make and model of the pump (ex. Hayward Super ll, Pentair WhisperFlow), and where the leak is. Your motor will fit a lot of different pumps. Thanks.
Feb 23, 2014 | AO Smith Pool & Spa
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
Jan 04, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
Can you put a bigger Hp and a smalll plully onit
There are quite a few variations of motor and pulley combinations. You can change the motor and pulley based on your needs, however do not over-clock the recommended rpm or the pump. Check the specifications of the pump to determine the max rpm . Usually the pulley on the motor will depend on the rpm of the motor. Check the rpm of the present motor to determing the rpm of the pump with current set-up, and compare to the motor you are considering. Motor rpm vary from around 850 to 3450 so pulley size is quite important. Good holidays
Dec 18, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I need a motor for flotec shallow well pump unit #FP7100-08.The motor #S48D02AO3.WHERE CAN I FIND ONE AND HOW MUCH.Thank you Greg
Save yourself time and effort, replace the entire unit. I speak as a guy who has lived with a well for more than 35 years.
If you put a new motor on a old pump what do you have? A new $300.00 motor on a $worthless old pump. Spend the $350.00 and replace it.
Oct 27, 2009 | Flotec Corrosion Resistant Shallow Well...
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
377 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
