Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator fan not working in the top part of the refrigerator
  • 120 Answers
Replace fan from parts warehouse.
Posted on Oct 06, 2009
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
Te fan in the freezer is on but not turning, thus the refrigerator will not cool. How do I get the fan to turn?
the fan in the top (back) of the freezer is the evaporator fan. when it stops the refrigerator will not work so you need to replace the fan. usually if enough screws are carefully removed the plastic around the fan will come out and the fan can be unbolted taken out and replaced. I would not try to oil up the fan as it will smell kinda funny in the refrigerator and it will fail again quite soon. They are not to expensive and can be bought from the appliance repair parts store. I would take the old fan out and take it right to the store so they can match it up with a replacement unit.
May 01, 2011 | Roper RT18HDXKQ Top Freezer Refrigerator
I have a Frigidaire top freezer refrigerator which stopped cooling the lower section while the top section stays frozen. I can hear it run through it's cycle but no freezer fan comes on. What would cause...
the evaporator fan is not spinning. the coil is getting too cold because the fan is not circulating the air across it. defrost it and see if the fan works. If not, they are fairly inexpensive and easy to replace. There is an access cover on the back wall of the freezer. remove it, and the fan is right behind it.
Nov 20, 2010 | Frigidaire FRT21H8C Top Freezer...
Top fan on True T19 noisy
no all the fans have to be working for the unit to work correctly
Feb 22, 2009 | True T-49 Side by Side Refrigerator...
I have ice in the refrig compartment at the top and freezer fan is not working
if fan is not working it will ice up , most likely bad fan ,remove fan and test it and see if it runs out of frig , or have it tested might need to replace fan
Feb 03, 2009 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator will not stay cold. The top of refrigeratoor is hot
if freezer is working correctly then fan is probably not working fan blows cold air from freezer into the fridge.
Jul 12, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
