Question about Lucent PARTNER18 Corded Phone
Phone has a code to get an outside line, how can i remove this code
  • 131 Answers
It needs to be unrestricted from main programming on x 10 or x 11
with admin login to progam. if you have the right to do it I can help. pretty simple.
Posted on Oct 21, 2009
Nec cant do inter office calls
Perhaps your phone automatically grabs an outside line, therefor when you dial you're making an outside call, so you need to grab the ICM line before making an internal call. Or, your phone is restricted from any calls without an access code, extremely rare.
Jul 02, 2014 | NEC Lands Phones
C710 Code on Copystar 2030
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
I have a phone it recieves calls but can't make them it was working until 2 days ago
Several things can go wrong. Do they need to dial an extension to access an outside line? Make sure they know this. Also, make certain to remove any area code in the menu settings. The phone could be trying to make a call, yet it dial the area code each time and screws up the PBX, so no outside line. There are more possibilities, but they require on site tests.
Jun 09, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
T7316 phone does not cancel call forwarding
#73 is a a feature you use on a telephone line to cancel call forwarding (cfw) of an outside call (some codes may differ). You need to have the dial tone of that outside line to cancel the cfw. to cancel the cfw of a norstar set (internal calls to extension) just press the cfw key or press 'feature #4'
Apr 15, 2014 | NorStar T7316E Corded Phone
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
Which is yours?
Carl
Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
How do I forward calls to an outside number on a panasonic kx-ta824 system. what is the line access code
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Oct 06, 2009 | Panasonic KX-TA824PK Phone
Is there a way to disallow all outside calls and
You could just remove the lines off of that extension:
1.Go to extension 10 or 11
2.Press (feature) (0) (0) (left intercom) (left intercom)
3.Press #301
4.Enter the extension # you want programmed.
5.Enter the line you want removed (line 1 =01 line 2 =02)
6.Press 2 to remove that line
7. Repeat steps 3-6 for all lines you have on that extensions.
Hope this helps!
Sep 01, 2009 | Lucent PARTNER18 Corded Phone
Speed Dialing KX-T7453
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Carl
Sep 18, 2008 | Panasonic KX-T7453 Corded Phone
Extension Phone Numbers
Press Superkey
press NO until personal keys? is displayed
Press YES
Press the desired Personal Key
make sure key is not programmed
Press Change
speed call will appear
Press YES
dial the number to be saved
include the outside access code and area code,if necessary
Press SAVE
Press SUPERKEY AGAIN TO EXIT
Jul 07, 2008 | Mitel Superset 420 Corded Phone
Lucent PARTNER18 Corded Phone Logo
43 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
